[pycsw-devel] Running on Windows
Tim Wanner tim_wanner at web.de
Sun Nov 18 12:51:25 PST 2018
Hi Tom,
Yes this will help. Thanks! So I got my python 2.7.13 installed in C:\Python27\Python that should do.
About the mod_wsgi: yes if considered this and will try to manage it. Running with python 2.7 + mod_wsgi for Apache conf. turns out to be very tricky (till impossible) as told on: https://github.com/GrahamDumpleton/mod_wsgi/blob/master/win32/README.rst <https://github.com/GrahamDumpleton/mod_wsgi/blob/master/win32/README.rst>
‚Python 2.7 is compiled with VC9‘
"The problem is that Apache Lounge, whose Apache binaries have been used up until this point, has stopped making available versions of Apache compiled with a VC9 compiler.
This means that if you hadn't managed to download a Win32 VC9 version of Apache at some time in the past, you technically can't use mod_wsgi on Windows with Python 2.6 or Python 2.7 any more as you can't get the right version of an Apache binary“
'The actual mod_wsgi binaries that are made available are:
Apache22-win32-VC9/modules/mod_wsgi-py27-VC9.so
Apache24-win32-VC9/modules/mod_wsgi-py27-VC9.so
Those labelled with Apache22-win32-VC9 should be used with an Apache 2.2 Win32 VC9 version of Apache. Alas Apache Lounge no longer makes such binaries available any more.
If you don't already have an older version of Apache which has been compiled with the Win32 VC9 compiler you are out of luck.’
"Note that Apache Lounge never made available any Win64 VC9 binaries for Apache 2.4.
This means that technically there is no combination available for correctly running mod_wsgi with a Win64 VC9 version of Python 2.6 or 2.7.“
At this point I’m not sure weather I can go with a pip install mod_wsgi or if that turns out to fail? Which mod_wsgi will it generate ? Depense this on the python version I’ll use for pip command right ?
So I’d go just with python 3.4 the whole lot as this is compiled with VC10 and there are fitting apache version available right ?
Thank a lot for your response this will help me a lot.
Tim
> Am 18.11.2018 um 14:53 schrieb Tom Kralidis <tom.kralidis at gmail.com>:
> Hi Tim:
> On Sun, Nov 18, 2018 at 6:34 AM Tim Wanner <tim_wanner at web.de> wrote:
>> Hello Mailing List,
>> this might be a 'beginner' question, but I couldn’t find a right description browsing the web and wanted to get this right in my Thesis.
>> As the pycsw doc tell’s you’ve got to change line 1 of csw.py into : #!/python27/python -u, bevor installation of pycsw on windows and running it on there.
>> Is this pointing to a UNIX (‚Ubuntu‘) directory somewhere external based to config the CGI handler and not to the Python version installed on the local windows computer ? (Win directory should be C:/python27/python.exe)
> As per http://docs.pycsw.org/en/stable/installation.html#running-on-windows ,
> the example assumes you have Python in \Python27\python .  The drive letter
> would be required if you are running if Python and your Python CGI script are
> on different paths.  Also note the -u flag for Windows environments
> (https://docs.python.org/3.3/using/cmdline.html#cmdoption-u)
> Having said this, have you considered running Python on mod_wsgi instead
> of CGI?  Many/most Python apps benefit from using mod_wsgi as a long
> running process for performance.
> Hope this helps.
> ..Tom
>> Or is this just a expression form where under windows apache searches for the python dir. self-sufficient where python is stored for running the CGI Wrapper ?
>> I would be pleased about a short background explanation.
>> Thanks for your response
>> Best Regards
>> Tim
>> pycsw-devel mailing list
>> pycsw-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20181118/564973da/attachment.html>
More information about the pycsw-devel mailing list
