[pycsw-devel] ElasticSearch integration
Tom Kralidis tom.kralidis at gmail.com
Tue Oct 9 09:50:01 PDT 2018
Mike: great news!  Note that the changes in csw2.py are already in
master and stable
releases.  The caller to your plugin will pass a constraint['_dict`]
parameter which
will be a dict-based representation of the OGC CSW query.  Your plugin will need
to translate this representation into an ES query syntax.
The files fes2es*.py are examples of how to do that as a first pass.  Note that
1./ this is relatively untested and based on the simpler/most common OGC CSW
filter queries
2./ you'll need to add support for spatial
3./ the result is an ES GET-based query string.  I'd suggest
transforming instead
to a POST-based JSON which provides more flexibility
Here's another example from the pygeoapi project to translate WFS3-based
queries (which are KVP and totally different that CSW Filter [XML
based] queries)
which might help in demonstrating how we craft ES queries in pygeoapi [1]
Hope this helps.
..Tom
[1] https://github.com/geopython/pygeoapi/blob/master/pygeoapi/provider/elasticsearch_.py#L100
On Tue, Oct 9, 2018 at 10:28 AM Mike Metcalfe <mike at webtide.co.za> wrote:
> Thanks Paolo and Tom,
> I copied the Hypermap plugin into plugins/repository/elastic/elastic.py and hacked it down to bare bones. I added a "source" param to default.cfg that points to that module and now when I call GetRecords it takes me to the query method in ElasticSearchRepository. Whoop!! I then started working on a method that that uses the requests library to call my ES service. But then I got Tom's suggestion to modify csw2.py and add fes2es modules but now I'm not sure how to merge these into what I have. Any and all pointers welcome.
> Mike
> On Tue, 9 Oct 2018 at 02:46, Tom Kralidis <tom.kralidis at gmail.com> wrote:
>> Hi Mike: thanks for the info and your interest in pycsw.
>> In the context of providing an 'outbound' CSW endpoint against an Elasticsearch
>> backend (this means the ES index already exists, and you want to bind pycsw
>> atop it), a repository plugin is the suggested approach.  The job of the plugin
>> would be to 1./ translate CSW queries into ES queries 2./ execute the ES
>> queries and 3./ format ES search results into pycsw objects back to the caller
>> There is an example in [1] that shows an example of OGC Filter to ES queries but
>> needs more development and testing.  Note that for ES spatial queries the
>> geo_shape type is recommended.
>> Hope this helps.
>> ..Tom
>> [1] https://gist.github.com/tomkralidis/6919d32da01b62b5b4e76b9254751e9b
>> On Thu, Oct 4, 2018 at 9:21 AM Mike Metcalfe <mike at webtide.co.za> wrote:
>> > Hi,
>> > On IRC recently @tomkralidis suggested I consider using the pycsw/HHyperman integration as the model on which to base the development of an elastic plugin.  Knowing hardly anything about pycsw, after reading this PR I had assumed I'd be writing a backend that would query ES and instead of a  SQL database. But the docs say "pycsw is enabled and configured by default in HHypermap".  Now after reading #208,  #410 and #95 I'm totally confused where to start.
>> > Please advise.
>> > Mike Metcalfe
>> > 082 903 8268
>> > www.webtide.co.za
>> > _______________________________________________
>> > pycsw-devel mailing list
>> > pycsw-devel at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/pycsw-devel
> Mike Metcalfe
> 082 903 8268
> www.webtide.co.za
More information about the pycsw-devel mailing list
