[pycsw-devel] ElasticSearch integration
Mike Metcalfe
mike at webtide.co.za
Tue Oct 9 07:27:51 PDT 2018
Thanks Paolo and Tom,
I copied the Hypermap plugin into plugins/repository/elastic/elastic.py and
hacked it down to bare bones. I added a "source" param to default.cfg that
points to that module and now when I call GetRecords it takes me to the
*query* method in *ElasticSearchRepository*. Whoop!! I then started working
on a method that that uses the requests
<http://docs.python-requests.org/en/master/> library to call my ES service.
But then I got Tom's suggestion to modify csw2.py and add fes2es modules
but now I'm not sure how to merge these into what I have. Any and all
pointers welcome.
Mike
On Tue, 9 Oct 2018 at 02:46, Tom Kralidis <tom.kralidis at gmail.com> wrote:
> Hi Mike: thanks for the info and your interest in pycsw.
> In the context of providing an 'outbound' CSW endpoint against an
> Elasticsearch
> backend (this means the ES index already exists, and you want to bind pycsw
> atop it), a repository plugin is the suggested approach. The job of the
> plugin
> would be to 1./ translate CSW queries into ES queries 2./ execute the ES
> queries and 3./ format ES search results into pycsw objects back to the
> caller
> There is an example in [1] that shows an example of OGC Filter to ES
> queries but
> needs more development and testing. Note that for ES spatial queries the
> geo_shape type is recommended.
> Hope this helps.
> ..Tom
> [1] https://gist.github.com/tomkralidis/6919d32da01b62b5b4e76b9254751e9b
> On Thu, Oct 4, 2018 at 9:21 AM Mike Metcalfe <mike at webtide.co.za> wrote:
> > Hi,
> > On IRC recently @tomkralidis suggested I consider using the
> pycsw/HHyperman integration as the model on which to base the development
> of an elastic plugin. Knowing hardly anything about pycsw, after reading
> this PR I had assumed I'd be writing a backend that would query ES and
> instead of a SQL database. But the docs say "pycsw is enabled and
> configured by default in HHypermap". Now after reading #208, #410 and #95
> I'm totally confused where to start.
> > Please advise.
> > Mike Metcalfe
> > 082 903 8268
> > www.webtide.co.za
> > pycsw-devel mailing list
> > pycsw-devel at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/pycsw-devel
Mike Metcalfe
082 903 8268
www.webtide.co.za
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20181009/132f9906/attachment.html>
More information about the pycsw-devel
