[pycsw-devel] ElasticSearch integration
Tom Kralidis tom.kralidis at gmail.com
Mon Oct 8 17:46:11 PDT 2018
Hi Mike: thanks for the info and your interest in pycsw.
In the context of providing an 'outbound' CSW endpoint against an Elasticsearch
backend (this means the ES index already exists, and you want to bind pycsw
atop it), a repository plugin is the suggested approach.  The job of the plugin
would be to 1./ translate CSW queries into ES queries 2./ execute the ES
queries and 3./ format ES search results into pycsw objects back to the caller
There is an example in [1] that shows an example of OGC Filter to ES queries but
needs more development and testing.  Note that for ES spatial queries the
geo_shape type is recommended.
Hope this helps.
..Tom
[1] https://gist.github.com/tomkralidis/6919d32da01b62b5b4e76b9254751e9b
On Thu, Oct 4, 2018 at 9:21 AM Mike Metcalfe <mike at webtide.co.za> wrote:
> Hi,
> On IRC recently @tomkralidis suggested I consider using the pycsw/HHyperman integration as the model on which to base the development of an elastic plugin.  Knowing hardly anything about pycsw, after reading this PR I had assumed I'd be writing a backend that would query ES and instead of a  SQL database. But the docs say "pycsw is enabled and configured by default in HHypermap".  Now after reading #208,  #410 and #95 I'm totally confused where to start.
> Please advise.
> Mike Metcalfe
> 082 903 8268
> www.webtide.co.za
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel mailing list
