[pycsw-devel] PyCSW Harvesting.
BRIAN STIFFENN LUNA BOLIVAR bslunab at correo.udistrital.edu.co
Thu Nov 12 15:25:49 PST 2020
 Hi Tom, sorry for the late response, I've been really busy, but I have
some really good news:
Last week I applied your recommendation, so I fellow this to configure
correctly the harvest:
1. Change my file post.xml and now look like this:
<Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:ows="http://www.opengis.net/ows"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd"
service="CSW" version="2.0.2">
  <Source>
http://127.0.0.1/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map
</Source>
  <ResourceType>http://www.opengis.net/wms</ResourceType>
  <ResourceFormat>application/xml</ResourceFormat>
</Harvest>
(I change http://localhost/... to  http://127.0.0.1/)
2. Run the following code: python bin/pycsw-admin.py -c post_xml -u
http://127.0.0.1/pycsw/csw.py -x C:/ms4w/DATA/post.xml
- Harvest works, at the end show:
...</csw:HarvestResponse>'
Done
3. Then execute the following: pycsw-admin.py -c load_records -p
/path/to/records -f default.cfg -y
4. Prove the csw in QGIS with MetaSearch and here appear my layers, so it
works PERFECTLY! Thank you so much for your help.
*Now I have a question: Does pyCSW generate an html document with the
layers and information in? *If not, how can I do this automatically just
with the GetCapabilities response?
Regards,
El mié., 14 oct. 2020 a las 5:54, Tom Kralidis (<tomkralidis at gmail.com>)
escribió:
> Hi Brian: it looks like the "&" characters in the <Source> element are
> causing XML parsing issues.  They are also
> not required in the context of a CSW Harvest request.  Can you update
> your XML request with just the base URL
> in <Source>?  The request parameters are autogenerated by pycsw
> accordingly:
>   <Source>
> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map
> </Source>
> </Harvest>
> Are you able to try again and report back?
> Thanks
> ..Tom
> On Tue, Oct 13, 2020 at 10:04 PM BRIAN STIFFENN LUNA BOLIVAR
> <bslunab at correo.udistrital.edu.co> wrote:
> > Thanks a lot for your response Tom, so I have a question, should I
> follow this steps to harvest a wms service:
> > 1. Modify the following XML request from my WMS service:
> https://github.com/geopython/pycsw/blob/master/tests/functionaltests/suites/harvesting/post/Harvest-wms-run1.xmlv
> (I named: post.xml and save it in c:\geiper\post\post.xml)
> > 2. Set in my default.cfg transactions=true
> > 3. When it's done, I should execute this command line:
> > python bin/pycsw-admin.py -c post_xml -u http://localhost/pycsw/csw.py
> -x c:\geiper\post\post.xml
> > 4. Refresh the harvested records with the following command line:
> > python bin/pycsw-admin.py  -c refresh_harvested_records -f default.cfg
> > Those were all the steps I must follow to harvest records from WMS?
> > If yes, I get the following error:
> > b'<?xml version="1.0" encoding="UTF-8" standalone="no"?>\n<!-- pycsw
> 2.4.2 -->\n<ows:ExceptionReport xmlns:csw="
> http://www.opengis.net/cat/csw/2.0.2" xmlns:dc="
> http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/"
> xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gml="
> http://www.opengis.net/gml" xmlns:ows="http://www.opengis.net/ows"
> xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" version="1.2.0"
> language="en-US" xsi:schemaLocation="http://www.opengis.net/ows
> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd"><ows:Exception
> exceptionCode="NoApplicableCode"
> locator="service"><ows:ExceptionText>Exception: document not
> well-formed.\nError: EntityRef: expecting \';\', line 3, column 95
> (<string>, line
> 3).</ows:ExceptionText></ows:Exception></ows:ExceptionReport>'
> > And My post.xml is formed like this:
> > <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="
> http://www.opengis.net/ogc" xmlns:gmd="http://www.isotc211.org/2005/gmd"
> xmlns:ows="http://www.opengis.net/ows" xmlns:xsd="
> http://www.w3.org/2001/XMLSchema" xmlns:dc="
> xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
> version="2.0.2">
> >   <Source>
> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0
> </Source>
> > </Harvest>
> > El mar., 13 oct. 2020 a las 19:28, Tom Kralidis (<tomkralidis at gmail.com>)
> escribió:
> >> Hi Brian: thanks for the info.  Comments interleaved:
> >> On Tue, Oct 13, 2020 at 4:13 PM BRIAN STIFFENN LUNA BOLIVAR
> >> > Hello everyone, good day. I have been trying for over a month to
> install and run pycsw, but I have not been fortunate enough to do it
> properly for my college degree work.
> >> What kind of installation problems are you having?
> >> > I currently have a WMS service in place which I need to run Harvest
> operation and be able to update the GetCapabilities of the CSW however, I
> have not found the right way to do it.
> >> > Could someone please provide me with a methodological guide to be
> able to run the Harvest operation to a WMS?
> >> You can run a CSW-T Harvest XML POST request with the following XML
> request:
> >> Here, you would replace the <Source> element content with your WMS
> >> base URL.  To invoke XML POST requests, see the following
> >> FAQ item: https://pycsw.org/faq/#how-can-i-make-csw-post-xml-requests
> >> Hope this helps.
> >> ..Tom
> >> > Q: I'm currently using Mapserver 7.7.0-dev in windows.
> >> > Regards.
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20201112/20439e3e/attachment.html>
More information about the pycsw-devel mailing list
