[pycsw-devel] PyCSW Harvesting.
BRIAN STIFFENN LUNA BOLIVAR bslunab at correo.udistrital.edu.co
Thu Nov 12 15:32:31 PST 2020
I have to report a problem but I don't know if this happens because of
pyCSW or qgis:
When I use the MetaSearch plugin, appears my layers from WMS, but when I
try to load a layer via WMS call, appears this error:
AttributeError: 'NoneType' object has no attribute 'addRasterLayer'
  File "C:/OSGEO4~1/apps/qgis-ltr/./python/plugins\MetaSearch\dialogs\maindialog.py",
line 757, in add_to_ows
    ows_provider.addRasterLayer.connect(self.iface.addRasterLayer)
Versión de Python: 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC
v.1914 64 bit (AMD64)]
Versión de QGIS: 3.10.6-A Coruña A Coruña, ec80021f49
Ruta de Python:
   - C:/OSGEO4~1/apps/qgis-ltr/./python
   - C:/Users/Brian Luna/AppData/Roaming/QGIS/QGIS3\profiles\default/python
   - C:/Users/Brian
   Luna/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
   - C:/OSGEO4~1/apps/qgis-ltr/./python/plugins
   - C:\OSGEO4~1\apps\Python37
   - C:\OSGEO4~1\apps\Python37\Scripts
   - C:\OSGeo4W64\bin\python37.zip
   - C:\OSGEO4~1\apps\Python37\DLLs
   - C:\OSGEO4~1\apps\Python37\lib
   - C:\OSGeo4W64\bin
   - C:\OSGEO4~1\apps\Python37\lib\site-packages
   - C:\OSGEO4~1\apps\Python37\lib\site-packages\win32
   - C:\OSGEO4~1\apps\Python37\lib\site-packages\win32\lib
   - C:\OSGEO4~1\apps\Python37\lib\site-packages\Pythonwin
Does anyone know the propertly way to solve it?
El jue., 12 nov. 2020 a las 18:25, BRIAN STIFFENN LUNA BOLIVAR (<
bslunab at correo.udistrital.edu.co>) escribió:
> Hi Tom, sorry for the late response, I've been really busy, but I have
> some really good news:
> Last week I applied your recommendation, so I fellow this to configure
> correctly the harvest:
> 1. Change my file post.xml and now look like this:
> <?xml version="1.0" encoding="UTF-8"?>
> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:gmd="http://www.isotc211.org/2005/gmd"
> xmlns:ows="http://www.opengis.net/ows"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns:dc="http://purl.org/dc/elements/1.1/"
> xmlns:dct="http://purl.org/dc/terms/"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd"
> service="CSW" version="2.0.2">
>   <Source>
> http://127.0.0.1/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map
> </Source>
>   <ResourceType>http://www.opengis.net/wms</ResourceType>
>   <ResourceFormat>application/xml</ResourceFormat>
> </Harvest>
> (I change http://localhost/... to  http://127.0.0.1/)
> 2. Run the following code: python bin/pycsw-admin.py -c post_xml -u
> http://127.0.0.1/pycsw/csw.py -x C:/ms4w/DATA/post.xml
> - Harvest works, at the end show:
> ...</csw:HarvestResponse>'
> Done
> 3. Then execute the following: pycsw-admin.py -c load_records -p
> /path/to/records -f default.cfg -y
> 4. Prove the csw in QGIS with MetaSearch and here appear my layers, so it
> works PERFECTLY! Thank you so much for your help.
> *Now I have a question: Does pyCSW generate an html document with the
> layers and information in? *If not, how can I do this automatically just
> with the GetCapabilities response?
> Regards,
> El mié., 14 oct. 2020 a las 5:54, Tom Kralidis (<tomkralidis at gmail.com>)
> escribió:
>> Hi Brian: it looks like the "&" characters in the <Source> element are
>> causing XML parsing issues.  They are also
>> not required in the context of a CSW Harvest request.  Can you update
>> your XML request with just the base URL
>> in <Source>?  The request parameters are autogenerated by pycsw
>> accordingly:
>>   <Source>
>> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map
>> </Source>
>> </Harvest>
>> Are you able to try again and report back?
>> Thanks
>> ..Tom
>> On Tue, Oct 13, 2020 at 10:04 PM BRIAN STIFFENN LUNA BOLIVAR
>> <bslunab at correo.udistrital.edu.co> wrote:
>> > Thanks a lot for your response Tom, so I have a question, should I
>> follow this steps to harvest a wms service:
>> > 1. Modify the following XML request from my WMS service:
>> https://github.com/geopython/pycsw/blob/master/tests/functionaltests/suites/harvesting/post/Harvest-wms-run1.xmlv
>> (I named: post.xml and save it in c:\geiper\post\post.xml)
>> > 2. Set in my default.cfg transactions=true
>> > 3. When it's done, I should execute this command line:
>> > python bin/pycsw-admin.py -c post_xml -u http://localhost/pycsw/csw.py
>> -x c:\geiper\post\post.xml
>> > 4. Refresh the harvested records with the following command line:
>> > python bin/pycsw-admin.py  -c refresh_harvested_records -f default.cfg
>> > Those were all the steps I must follow to harvest records from WMS?
>> > If yes, I get the following error:
>> > b'<?xml version="1.0" encoding="UTF-8" standalone="no"?>\n<!-- pycsw
>> 2.4.2 -->\n<ows:ExceptionReport xmlns:csw="
>> http://www.opengis.net/cat/csw/2.0.2" xmlns:dc="
>> http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/"
>> xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gml="
>> http://www.opengis.net/gml" xmlns:ows="http://www.opengis.net/ows"
>> xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="
>> http://www.w3.org/2001/XMLSchema-instance" version="1.2.0"
>> language="en-US" xsi:schemaLocation="http://www.opengis.net/ows
>> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd"><ows:Exception
>> exceptionCode="NoApplicableCode"
>> locator="service"><ows:ExceptionText>Exception: document not
>> well-formed.\nError: EntityRef: expecting \';\', line 3, column 95
>> (<string>, line
>> 3).</ows:ExceptionText></ows:Exception></ows:ExceptionReport>'
>> > And My post.xml is formed like this:
>> > <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="
>> http://www.opengis.net/ogc" xmlns:gmd="http://www.isotc211.org/2005/gmd"
>> xmlns:ows="http://www.opengis.net/ows" xmlns:xsd="
>> http://www.w3.org/2001/XMLSchema" xmlns:dc="
>> xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="
>> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
>> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
>> version="2.0.2">
>> >   <Source>
>> http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0
>> </Source>
>> > </Harvest>
>> > El mar., 13 oct. 2020 a las 19:28, Tom Kralidis (<tomkralidis at gmail.com>)
>> escribió:
>> >> Hi Brian: thanks for the info.  Comments interleaved:
>> >> On Tue, Oct 13, 2020 at 4:13 PM BRIAN STIFFENN LUNA BOLIVAR
>> >> > Hello everyone, good day. I have been trying for over a month to
>> install and run pycsw, but I have not been fortunate enough to do it
>> properly for my college degree work.
>> >> What kind of installation problems are you having?
>> >> > I currently have a WMS service in place which I need to run Harvest
>> operation and be able to update the GetCapabilities of the CSW however, I
>> have not found the right way to do it.
>> >> > Could someone please provide me with a methodological guide to be
>> able to run the Harvest operation to a WMS?
>> >> You can run a CSW-T Harvest XML POST request with the following XML
>> request:
>> >> Here, you would replace the <Source> element content with your WMS
>> >> base URL.  To invoke XML POST requests, see the following
>> >> FAQ item: https://pycsw.org/faq/#how-can-i-make-csw-post-xml-requests
>> >> Hope this helps.
>> >> ..Tom
>> >> > Q: I'm currently using Mapserver 7.7.0-dev in windows.
>> >> > Regards.
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20201112/43895a99/attachment-0001.html>
More information about the pycsw-devel mailing list
