[pycsw-devel] PyCSW Harvesting.
Tom Kralidis tomkralidis at gmail.com
Wed Oct 14 03:54:04 PDT 2020
Hi Brian: it looks like the "&" characters in the <Source> element are
causing XML parsing issues.  They are also
not required in the context of a CSW Harvest request.  Can you update
your XML request with just the base URL
in <Source>?  The request parameters are autogenerated by pycsw accordingly:
<Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:ows="http://www.opengis.net/ows"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd"
service="CSW" version="2.0.2">
  <Source>http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map</Source>
  <ResourceType>http://www.opengis.net/wms</ResourceType>
  <ResourceFormat>application/xml</ResourceFormat>
</Harvest>
Are you able to try again and report back?
Thanks
..Tom
On Tue, Oct 13, 2020 at 10:04 PM BRIAN STIFFENN LUNA BOLIVAR
<bslunab at correo.udistrital.edu.co> wrote:
> Thanks a lot for your response Tom, so I have a question, should I follow this steps to harvest a wms service:
> 1. Modify the following XML request from my WMS service: https://github.com/geopython/pycsw/blob/master/tests/functionaltests/suites/harvesting/post/Harvest-wms-run1.xmlv (I named: post.xml and save it in c:\geiper\post\post.xml)
> 2. Set in my default.cfg transactions=true
> 3. When it's done, I should execute this command line:
> python bin/pycsw-admin.py -c post_xml -u http://localhost/pycsw/csw.py -x c:\geiper\post\post.xml
> 4. Refresh the harvested records with the following command line:
> python bin/pycsw-admin.py  -c refresh_harvested_records -f default.cfg
> Those were all the steps I must follow to harvest records from WMS?
> If yes, I get the following error:
> b'<?xml version="1.0" encoding="UTF-8" standalone="no"?>\n<!-- pycsw 2.4.2 -->\n<ows:ExceptionReport xmlns:csw="http://www.opengis.net/cat/csw/2.0.2" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gml="http://www.opengis.net/gml" xmlns:ows="http://www.opengis.net/ows" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.2.0" language="en-US" xsi:schemaLocation="http://www.opengis.net/ows http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd"><ows:Exception exceptionCode="NoApplicableCode" locator="service"><ows:ExceptionText>Exception: document not well-formed.\nError: EntityRef: expecting \';\', line 3, column 95 (<string>, line 3).</ows:ExceptionText></ows:Exception></ows:ExceptionReport>'
> And My post.xml is formed like this:
> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:ows="http://www.opengis.net/ows" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="http://purl.org/dc/terms/" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW" version="2.0.2">
>   <Source>http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0</Source>
> </Harvest>
> Thank you so much for your help.
> El mar., 13 oct. 2020 a las 19:28, Tom Kralidis (<tomkralidis at gmail.com>) escribió:
>> Hi Brian: thanks for the info.  Comments interleaved:
>> On Tue, Oct 13, 2020 at 4:13 PM BRIAN STIFFENN LUNA BOLIVAR
>> > Hello everyone, good day. I have been trying for over a month to install and run pycsw, but I have not been fortunate enough to do it properly for my college degree work.
>> What kind of installation problems are you having?
>> > I currently have a WMS service in place which I need to run Harvest operation and be able to update the GetCapabilities of the CSW however, I have not found the right way to do it.
>> > Could someone please provide me with a methodological guide to be able to run the Harvest operation to a WMS?
>> You can run a CSW-T Harvest XML POST request with the following XML request:
>> Here, you would replace the <Source> element content with your WMS
>> base URL.  To invoke XML POST requests, see the following
>> FAQ item: https://pycsw.org/faq/#how-can-i-make-csw-post-xml-requests
>> Hope this helps.
>> ..Tom
>> > Q: I'm currently using Mapserver 7.7.0-dev in windows.
>> > Regards.
More information about the pycsw-devel mailing list
