[pycsw-devel] PyCSW Harvesting.
BRIAN STIFFENN LUNA BOLIVAR
bslunab at correo.udistrital.edu.co
Tue Oct 13 19:03:58 PDT 2020
Thanks a lot for your response Tom, so I have a question, should I follow
this steps to harvest a wms service:
1. Modify the following XML request from my WMS service:
https://github.com/geopython/pycsw/blob/master/tests/functionaltests/suites/harvesting/post/Harvest-wms-run1.xmlv
<https://github.com/geopython/pycsw/blob/master/tests/functionaltests/suites/harvesting/post/Harvest-wms-run1.xml>
(I named: post.xml and save it in c:\geiper\post\post.xml)
2. Set in my default.cfg transactions=true
3. When it's done, I should execute this command line:
python bin/pycsw-admin.py -c post_xml -u http://localhost/pycsw/csw.py -x
4. Refresh the harvested records with the following command line:
python bin/pycsw-admin.py -c refresh_harvested_records -f default.cfg
Those were all the steps I must follow to harvest records from WMS?
If yes, I get the following error:
b'<?xml version="1.0" encoding="UTF-8" standalone="no"?>\n<!-- pycsw 2.4.2
-->\n<ows:ExceptionReport xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="
http://purl.org/dc/terms/" xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:gml="http://www.opengis.net/gml" xmlns:ows="http://www.opengis.net/ows"
xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" version="1.2.0" language="en-US"
xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd"><ows:Exception
exceptionCode="NoApplicableCode"
locator="service"><ows:ExceptionText>Exception: document not
well-formed.\nError: EntityRef: expecting \';\', line 3, column 95
(<string>, line
3).</ows:ExceptionText></ows:Exception></ows:ExceptionReport>'
And My post.xml is formed like this:
<Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2" xmlns:ogc="
http://www.opengis.net/ogc" xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:ows="http://www.opengis.net/ows" xmlns:xsd="
http://www.w3.org/2001/XMLSchema" xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/" xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
version="2.0.2">
<Source>
http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/DATA/geoserviciosgeiper.map&SERVICE=WMS&VERSION=1.3.0
</Source>
<ResourceType>http://www.opengis.net/wms</ResourceType>
<ResourceFormat>application/xml</ResourceFormat>
</Harvest>
Thank you so much for your help.
El mar., 13 oct. 2020 a las 19:28, Tom Kralidis (<tomkralidis at gmail.com>)
escribió:
> Hi Brian: thanks for the info. Comments interleaved:
> On Tue, Oct 13, 2020 at 4:13 PM BRIAN STIFFENN LUNA BOLIVAR
> <bslunab at correo.udistrital.edu.co> wrote:
> > Hello everyone, good day. I have been trying for over a month to install
> and run pycsw, but I have not been fortunate enough to do it properly for
> my college degree work.
> What kind of installation problems are you having?
> > I currently have a WMS service in place which I need to run Harvest
> operation and be able to update the GetCapabilities of the CSW however, I
> have not found the right way to do it.
> > Could someone please provide me with a methodological guide to be able
> to run the Harvest operation to a WMS?
> You can run a CSW-T Harvest XML POST request with the following XML
> request:
> Here, you would replace the <Source> element content with your WMS
> base URL. To invoke XML POST requests, see the following
> FAQ item: https://pycsw.org/faq/#how-can-i-make-csw-post-xml-requests
> Hope this helps.
> ..Tom
> > Q: I'm currently using Mapserver 7.7.0-dev in windows.
> > Regards.
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20201013/c8561137/attachment.html>
More information about the pycsw-devel
