[Pywps-dev] Fwd: pywps-dev post from jachym at les-ejk.cz requires approval
Tom Kralidis
tomkralidis at hotmail.com
Thu May 16 18:17:01 PDT 2013
If you're looking for discovery of WPS instances and processes, your best bet is to harvest the WPS from a CSW. pycsw can harvest WPS 1.0.0. You can deploy PyWPS and pycsw with a common WSGI instance and just run a local harvest periodically. Extremely lightweight.
If you're looking to manage PyWPS process identification type metadata in a database instead of setting this in your process definition in your Python file/module, then this is something best handled in PyWPS. Perhaps we can define a lightweight process metadata model in PyWPS for this, and then have PyWPS configuration be able to set that process ident/metadata comes from a DB?
Date: Thu, 16 May 2013 08:53:04 +0200
To: pywps-dev at lists.osgeo.org
Subject: [Pywps-dev] Fwd: pywps-dev post from jachym at les-ejk.cz requires approval
please join pywps-dev at lists.osgeo.org
I think, the ideas you presented are very valuable, someone with
experience in parallel programming is needed!
I think, with GeoServer REST API (I recently made some experience with
it), connection to GeoServer should be implementable (so the user could
make choice, what to use for output data publishing)
For process searching, I'm not sure, whether it makes sense to put those
informations (title, abstract etc.) to database. CS-W servers are
usually able to harvest the informations from GetCapabilities document
(Tom Kralidis knows maybe more then me about it).
Jachym
Dne 16.5.2013 01:16, welkin zzp napsal(a):
> On 2013年05月13日 05:20, Jachym Cepicky wrote:
>> (sorry for cross posting)
> Hi Jachym
> I have used pywps about two years from first touch wps specification,
> and want to contribute pywps with some suggestions:
> I'm involving in parallel program,so if parallel program scheduling and
> managing can be supported at pywps;
> May be the easy in learning or other reasons, many administrator and
> students more like using Geoserver,
> I think if we can design an abstract interface or bridge concept for
> supporting data storaged in different map server;
> For searching processes in the way like CSW, if we can set the
> description information, like title,abstract,etc, to database
> like SQLite. It's easy to extend the content, as category,
> keywords,execution implement language of processess, for other
> application or project and more effect to search more than OGC WPS http
> interface supported in such way.
> Thanks
--Forwarded Message Attachment--
Date: Thu, 16 May 2013 07:46:11 +0200
To: zzpwelkin at gmail.com; pywps-dev at lists.osgeo.org
Subject: Re: [Pywps-devel] Invitation to new PyWPS development
Jachym
> Hi Jachym
> Thanks
Jachym Cepicky
http://les-ejk.cz
Subject: confirm 47d5c5a646fec64da0ed6e4bf8dec8185177ca2d
Date: Wed, 15 May 2013 22:53:33 -0700
If you reply to this message, keeping the Subject: header intact,
Mailman will discard the held message. Do this if the message is
spam. If you reply to this message and include an Approved: header
with the list password in it, the message will be approved for posting
to the list. The Approved: header can also appear in the first line
of the body of the reply.
pywps-dev mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
More information about the pywps-dev
