[Pywps-dev] [Pywps-devel] Invitation to new PyWPS development
Jachym Cepicky
jachym at les-ejk.cz
Wed May 15 22:46:11 PDT 2013
please join pywps-dev at lists.osgeo.org
I think, the ideas you presented are very valuable, someone with
experience in parallel programming is needed!
I think, with GeoServer REST API (I recently made some experience with
it), connection to GeoServer should be implementable (so the user could
make choice, what to use for output data publishing)
For process searching, I'm not sure, whether it makes sense to put those
informations (title, abstract etc.) to database. CS-W servers are
usually able to harvest the informations from GetCapabilities document
(Tom Kralidis knows maybe more then me about it).
Jachym
Dne 16.5.2013 01:16, welkin zzp napsal(a):
> On 2013年05月13日 05:20, Jachym Cepicky wrote:
>> (sorry for cross posting)
> Hi Jachym
> I have used pywps about two years from first touch wps specification,
> and want to contribute pywps with some suggestions:
> I'm involving in parallel program,so if parallel program scheduling and
> managing can be supported at pywps;
> May be the easy in learning or other reasons, many administrator and
> students more like using Geoserver,
> I think if we can design an abstract interface or bridge concept for
> supporting data storaged in different map server;
> For searching processes in the way like CSW, if we can set the
> description information, like title,abstract,etc, to database
> like SQLite. It's easy to extend the content, as category,
> keywords,execution implement language of processess, for other
> application or project and more effect to search more than OGC WPS http
> interface supported in such way.
> Thanks
Jachym Cepicky
http://les-ejk.cz
More information about the pywps-dev
