[Pywps-dev] how to using GeoServer REST API to save output data to GeoServer
Tom Kralidis
tomkralidis at hotmail.com
Tue May 21 03:47:50 PDT 2013
Depends in how much XML work is part of the codebase. If significant I would use lxml which gives you the control and lets you write/parse with ease and namespace support.
Sent from my iPhone
On 2013-05-21, at 3:51, "Jorge de Jesus" <jorge.mendesdejesus at wur.nl> wrote:
> Goede Morgen
> Reply inline:
> On 05/21/2013 08:27 AM, Jachym Cepicky wrote:
>> Jorge,
>> do I understand it correctly, that all proposed libraries are to be used
>> at server side - so inside of PyWPS?
> Yes, everything inside PyWPS and being called from inside the code. The
> same concerning QGIS, our code needs to be properly done so that it will
> be easy to write a plugin to QGIS, meaning "import pywps", a bit like I
> wrote in the wiki:
> http://wiki.rsg.pml.ac.uk/pywps/API_access
>> In which way are you proposing using REST approach inside of PyWPS? My
>> ideas would be:
>> 1 - using it for administration (list of running processes, statistics,
>> stoping/pausing/starting process (NOTE: future version of WPS will
>> include this features as well) ...
> Yes, maybe also some nice web page interface ???
>> 2 - Along with "old" way of defining and deploying processes, we could
>> use REST services to do so
> This is just an extension from point 1, it will be "natural" to
> implement it
>> 3 - make completely new proprietary design of processing service
>> (something like web processing server, demonstrated along with
>> OpenLayers some years ago)
> I'm not certain what you mean as web processing server, you mean a
> complete application supporting HTTP calls ???? A sort of framework ?
>> 4 - anything else?
>> About the templates: I would like to KISS pywps - helping libraries are
>> as good, as they are helping. My original idea was, to use lxml for
>> output xml generation, so no templates needed. What's your opinion?
> To many chefs in the kitchen can be a disaster :) I've recalled that you
> also wanted XML parsing capabilities in the output (in debug mode). A
> template approach for the output would be faster. BUT to many components
> break the KISS approach, for me is not a problem.
> Cheers
>> Jachym
>> Dne 21.5.2013 08:12, Jorge de Jesus napsal(a):
>>> Hola
>>> I think that GeoServer REST API is nice and well documented if, we use
>>> it as reference point we will have a great start.
>>> 1 year go my college Olly suggested to do REST services using Flask [1]
>>> I've done a REST access in ISRIC using Flask, the framework performed
>>> pretty well I only had some problems with pyscopg2 and cursors but this
>>> problem is independent from Flask. Also Django-REST looks nice [2], and
>>> future developments on my side will use Django-REST.
>>> Flask uses Jinja [3] as template engine, it seems that template engines
>>> and webframes are breeding like rabbits :)
>>> Any considerations for the new template engine ??? We need to shop
>>> around for new tools and frameworks, Python has come a long long way
>>> since PyWPS started.
>>> Jorge
>>> [1] http://flask.pocoo.org/
>>> [2] http://django-rest-framework.org/
>>> [2] http://jinja.pocoo.org/
>>> On 05/20/2013 04:17 AM, welkin zzp wrote:
>>>> Hi Jachym
>>>> I want to implement the function that write output data to
>>>> GeoServer , but I have not used Geoserver and not very familiar with
>>>> the Geoserver REST API , Can you give me some advice on how to implement
>>>> this feature in pywps ?
>>>> Thanks
>>>> _______________________________________________
>>>> pywps-dev mailing list
>>>> pywps-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
> ISRIC - World Soil Information Post: PO box 353, 6700 AJ, Wageningen,
> The Netherlands Visiting Address: Droevendaalsesteeg 3, 6708 PB
> Wageningen (Bdg. 101), Office: C.013 Office Phone: +31 (0) 317 4 83715
> Mobile Phone: +31 (0) 613 9 06950 OpenPGPKey: 0xA3D0065A
More information about the pywps-dev
