[Pywps-dev] how to using GeoServer REST API to save output data to GeoServer
Jachym Cepicky jachym.cepicky at gmail.com
Wed May 22 02:27:15 PDT 2013
[cced to pywps-dev]
Dne 22.5.2013 05:25, welkin zzp napsal(a):
> Hi  Jachym:
>     I' sorry for bothering you again, some problems hinder me unable to
> move forward when I was learning to use REST API to
> upload output data to GeoServer, and I need your suggestions ,the first
> question is when I create a new workspace how should I
> set the enabled services like WFS/WCS that this workespace will be
> providing,
I think, we have to this by hand in the geoserver administration
interface, in the workspace configuration
> the second problem is what is the correction
> method that upload an raster file?
If you by "correction" mean "correct", I think, following has to be done:
1) upload/copy raster file to geoserver database
2) publish inside some workspace, e.g. using gsconfig.py
        # create geoserver connection
	cat = Catalog("http://localhost:8080/geoserver/rest", "admin", "geoserver")
	# get already created workspace, the name will be probably in config
file of pywps in the future
	ws = cat.get_workspace("ws_name")
	# create coveragestore with given data
	cov  = cat.create_coveragestore(self, output_name, data, workspace=ws,
overwrite=False)
It should be more descriptive in test/catalogtests.py of gsconfig.py
Jachym
Jachym Cepicky
Help Service - Remote Sensing s.r.o.
HS-RS: jachym at hsrs.cz http://bnhelp.cz
http://les-ejk.cz
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20130522/fda59a9e/attachment.pgp>
More information about the pywps-dev mailing list
