[Pywps-dev] pywps-4 and ogc cite tests
Jachym Cepicky jachym.cepicky at gmail.com
Sun Jul 5 17:40:11 PDT 2015
Hi all,
after successful deployment of PyWPS-4 on the server (for playing around
you can use pywps.cloudapp.net), I've started to have a look at OGC Cite
tests. The result is not so good, we have to work on it a bit.
If you wanna help,
1 - you have to go to http://cite.opengeospatial.org/te2/
2 - at the bottom of the page, you have to sign in
3 - create testing session
4 - fill the url of PyWPS instance
5 - have a look at bugs, fix on the server (apparently, you can not do this
for pywps.cloudapp.net  and localhost dost not help
6 - start the whole testing session again (you have to perform all the
steps by hand again, reloading does not help)
Sofar, I've tested getcapabilities.
1 - Metadata should not contain any strings
2 - processVersion should be filled (and it is  not wps:processVersion
3 - in the header of the capabilities document, reference to
DescribeProcess response xsd is present
I'll try to make those things work
Jachym
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20150706/a679982f/attachment.html>
More information about the pywps-dev mailing list
