[Pywps-dev] pywps-4 and ogc cite tests
Tom Kralidis tomkralidis at gmail.com
Sun Jul 5 17:58:19 PDT 2015
Hi Jachym: glad to see this!  Giving experience from pycsw, the CITE tests are
an invaluable resource to ensuring compliance over the long term.
I'm not familiar with ets-wps10, but for the CSW case we work with all CSW
test suites on the command line to build and execute tests automatically.  This
also makes it very straightforward to run the CITE test as part of a travis-ci
setup.  I'm guessing similar functionality might be available in CITE WPS
which would make your test/investigate/fix cycle much easier.
..Tom
On Sun, Jul 5, 2015 at 8:40 PM, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi all,
> after successful deployment of PyWPS-4 on the server (for playing around you
> can use pywps.cloudapp.net), I've started to have a look at OGC Cite tests.
> The result is not so good, we have to work on it a bit.
> If you wanna help,
> 1 - you have to go to http://cite.opengeospatial.org/te2/
> 2 - at the bottom of the page, you have to sign in
> 3 - create testing session
> 4 - fill the url of PyWPS instance
> 5 - have a look at bugs, fix on the server (apparently, you can not do this
> for pywps.cloudapp.net  and localhost dost not help
> 6 - start the whole testing session again (you have to perform all the steps
> by hand again, reloading does not help)
> Sofar, I've tested getcapabilities.
> 1 - Metadata should not contain any strings
> 2 - processVersion should be filled (and it is  not wps:processVersion
> 3 - in the header of the capabilities document, reference to DescribeProcess
> response xsd is present
> I'll try to make those things work
> Jachym
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
