[Pywps-dev] pywps-4 and ogc cite tests
Luís de Sousa
luis.a.de.sousa at gmail.com
Tue Jul 7 07:35:44 PDT 2015
Hi Jachym,
Is there a way to see the precise request used for each test? I would
like to register these failures as issues at GitHub.
Another thing: the tests did not run on Firefox, I had to use Chromium.
Cheers,
Luís
On 6 July 2015 at 02:58, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi Jachym: glad to see this! Giving experience from pycsw, the CITE tests are
> an invaluable resource to ensuring compliance over the long term.
> I'm not familiar with ets-wps10, but for the CSW case we work with all CSW
> test suites on the command line to build and execute tests automatically. This
> also makes it very straightforward to run the CITE test as part of a travis-ci
> setup. I'm guessing similar functionality might be available in CITE WPS
> which would make your test/investigate/fix cycle much easier.
> ..Tom
> On Sun, Jul 5, 2015 at 8:40 PM, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
>> Hi all,
>> after successful deployment of PyWPS-4 on the server (for playing around you
>> can use pywps.cloudapp.net), I've started to have a look at OGC Cite tests.
>> The result is not so good, we have to work on it a bit.
>> If you wanna help,
>> 1 - you have to go to http://cite.opengeospatial.org/te2/
>> 2 - at the bottom of the page, you have to sign in
>> 3 - create testing session
>> 4 - fill the url of PyWPS instance
>> 5 - have a look at bugs, fix on the server (apparently, you can not do this
>> for pywps.cloudapp.net and localhost dost not help
>> 6 - start the whole testing session again (you have to perform all the steps
>> by hand again, reloading does not help)
>> Sofar, I've tested getcapabilities.
>> 1 - Metadata should not contain any strings
>> 2 - processVersion should be filled (and it is not wps:processVersion
>> 3 - in the header of the capabilities document, reference to DescribeProcess
>> response xsd is present
>> I'll try to make those things work
>> Jachym
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
More information about the pywps-dev
