[Pywps-dev] Referenced Input
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Mar 30 01:46:08 PDT 2015
AFAIK, im PyWPS-4, I've started to think about Reference input in more
complex way, than I did in PyWPS 3.
IMHO References are intended to be used as ComplexIn/Outputs, but ...
theoretically, it's possible to pass *any* in/output object type with them.
Even it might sound like overkill, to use it for literalvalue, it could be
used, therefore, I would suggest to use Reference as generic in/out handler.
Also beaware of WPS
2.0 file:///home/jachym/Sta%C5%BEen%C3%A9/14-065_OGC_WPS_2.0_Interface_Standard.pdf
where inputs and outputs can be even more complex
J
pá 27. 3. 2015 v 15:10 odesílatel Calin Ciociu <calin.ciociu at gmail.com>
napsal:
> Hello everyone,
> I am currently working on referenced input data.
> Is this always considered a ComplexInput? I wonder if there is any sense
> to have referenced LiteralInput.
> Furthermore, identifying input data as Literal, Complex, Reference,
> BoundingBox as described in 10.2.2.1.1 in OGC 05-007r7 is not really
> clear to me.
> Should I only check for the passed attributes to see what type it is and
> just take the input as a Literal as default solution?
> Best regards,
> Calin Ciociu
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20150330/11efd56e/attachment.html>
More information about the pywps-dev
