[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Robin Skahjem-Eriksen
skahjem-eriksen at stcorp.no
Tue Apr 19 02:09:00 PDT 2016
I am trying to get pywps working so that a ResponseDocument is used to show
the process status, by having the Execute response provide a URL to the
ResponseDocument, as specified in the WPS 1.0 standard.
I am not sure if pywps actually supports this and if so, the feature is not
well documented. I see that pywps supports serving output files and serving
these, and I was hoping that this could be used to provide the response
document.
I initialize a Process object with `store_supported` and `status_supported`
set to `True` and provide `storeExecuteResponse=true` in the GET request.
However, I haven't manged to receive a response containing the
`executeResponseLocation` element, and I cannot find any code in the master
branch code base that handles an `ExecuteResponseLocation`.
Am I missing anything, or is this feature simply not supported by pywps?
Med vennlig hilsen / With kind regards,
Software developer
Science [&] Technology AS
Reg. nr.: 996 229 009 MVA
[E]: [skahjem-eriksen at stcorp.no](mailto:skahjem-eriksen at stcorp.no)
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[W]: <http://www.stcorp.no>
[P]:+47 45 911 694
[E]: [info at stcorp.no](mailto:info at stcorp.no)
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160419/35a07140/attachment.html>
More information about the pywps-dev
