[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Jonas Eberle jonas.eberle at gmx.de
Tue Apr 19 12:26:19 PDT 2016
Hi Robin,
I guess you're looking for the "statusLocation" attribute of the ExecuteResponse tag. The value of this attribute is the URL to the response document, especially needed when you use asynchronous execution (both, status=true and storeExecuteResponse=true, needed in the execute request). There is no executeResponseLocation element, please see the "Corrigendum for OpenGIS Implementation Standard Web Processing Service (WPS) 1.0.0 (0.0.8)" [1].
Best regards,
Jonas
[1] = http://portal.opengeospatial.org/files/?artifact_id=32766
----- Am 19. Apr 2016 um 11:09 schrieb Robin Skahjem-Eriksen <skahjem-eriksen at stcorp.no>:
> I am trying to get pywps working so that a ResponseDocument is used to show the
> process status, by having the Execute response provide a URL to the
> ResponseDocument, as specified in the WPS 1.0 standard.
> I am not sure if pywps actually supports this and if so, the feature is not well
> documented. I see that pywps supports serving output files and serving these,
> and I was hoping that this could be used to provide the response document.
> I initialize a Process object with `store_supported` and `status_supported` set
> to `True` and provide `storeExecuteResponse=true` in the GET request. However,
> I haven't manged to receive a response containing the `executeResponseLocation`
> element, and I cannot find any code in the master branch code base that handles
> an `ExecuteResponseLocation`.
> Am I missing anything, or is this feature simply not supported by pywps?
> Med vennlig hilsen / With kind regards,
> Software developer
> Science [&] Technology AS
> Reg. nr.: 996 229 009 MVA
> [E]: skahjem-eriksen at stcorp.no
> [Address]:
> Forskningsparken
> Gaustadalléen 21
> 0349 Oslo
> Norway
> [W]: http://www.stcorp.no
> [P]:+47 45 911 694
> [E]: info at stcorp.no
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160419/036344a6/attachment.html>
More information about the pywps-dev mailing list
