[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Luís de Sousa
luis.de.sousa at protonmail.ch
Wed Apr 20 10:41:00 PDT 2016
Hi again,
You have not posted the code of your process, which I understand. I suggest you check the PyWPS logs. If I remember correctly, this exception can also be raised if PyWPS fails to import the process, e.g. due to a compilation error.
Cheers,
Luís
Sent from [ProtonMail](https://protonmail.ch), encrypted email based in Switzerland.
-------- Original Message --------
Subject: Re: [Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Local Time: 20 April 2016 2:18 PM
UTC Time: 20 April 2016 13:18
To: luis.de.sousa at protonmail.ch
CC: jonas.eberle at gmx.de,pywps-dev at lists.osgeo.org
Why do you think it's a bug with my process? I have provided both the Process and the request, so I would appreciate it if you could point out where exactly the problem stems from.
Thank you.
Med vennlig hilsen / With kind regards,
Robin Skahjem-Eriksen
Software developer
Science [&] Technology AS
Reg. nr.: 996 229 009 MVA
[E]: skahjem-eriksen at stcorp.no
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[W]: http://www.stcorp.no
[P]:+47 45 911 694
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160420/978b2262/attachment.html>
More information about the pywps-dev
