[Pywps-dev] PyWPS support for ExecuteResponseLocation, providing process status
Robin Skahjem-Eriksen skahjem-eriksen at stcorp.no
Thu Apr 21 05:12:16 PDT 2016
I think I understand now. When you write "process" do you mean the definition
in pywps, or do you mean the actual processor application that is executed
through pywps?
If it's the latter, I'm not sure I am allowed to share this code and even if I
could, the code base is quite significant. But thanks for the feedback.
Med vennlig hilsen / With kind regards,
Software developer
Science [&] Technology AS
Reg. nr.: 996 229 009 MVA
[E]: [skahjem-eriksen at stcorp.no](mailto:skahjem-eriksen at stcorp.no)
[Address]:
Forskningsparken
Gaustadalléen 21
0349 Oslo
Norway
[W]: <http://www.stcorp.no>
[P]:+47 45 911 694
[E]: [info at stcorp.no](mailto:info at stcorp.no)
> On Apr 20 2016, at 7:41 pm, Luí­s de Sousa
<luis.de.sousa at protonmail.ch> wrote:
Hi again,
You have not posted the code of your process, which I understand. I suggest
you check the PyWPS logs. If I remember correctly, this exception can also be
raised if PyWPS fails to import the process, e.g. due to a compilation error.
Cheers,
Luís
> _Sent from [ProtonMail](https://protonmail.ch), encrypted email based in
Switzerland._
>> \-------- Original Message --------
>> Subject: Re: [Pywps-dev] PyWPS support for ExecuteResponseLocation,
>> Local Time: 20 April 2016 2:18 PM
>> UTC Time: 20 April 2016 13:18
>> From: [skahjem-eriksen at stcorp.no](mailto:skahjem-eriksen at stcorp.no)
>> To: [luis.de.sousa at protonmail.ch](mailto:luis.de.sousa at protonmail.ch)
>> CC: [jonas.eberle at gmx.de](mailto:jonas.eberle at gmx.de),[pywps-
dev at lists.osgeo.org](mailto:pywps-dev at lists.osgeo.org)
>> Why do you think it's a bug with my process? I have provided both the
Process and the request, so I would appreciate it if you could point out where
exactly the problem stems from.
>> Thank you.
>> Software developer
>> [Address]:
>> Forskningsparken
>> Gaustadalléen 21
>> 0349 Oslo
>> Norway
>> [P]:+47 45 911 694
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160421/260d0485/attachment.html>
More information about the pywps-dev mailing list
