[Pywps-dev] bonn workshop - pywps-demo back to work
Luís de Sousa
luis.de.sousa at protonmail.ch
Mon Aug 1 03:54:05 PDT 2016
Ok, I'll try that one. I tried the pywps-demo from the geopython organisation this morning and it is not working.
One thing that bothers me: if something goes wrong before Flask is up there is no way to tell what is happening (except debugging). The other day I had a messed up GDAL version and the demo application would simply fail without logging anything or issuing exceptions....
Luís
Sent from [ProtonMail](https://protonmail.ch), encrypted email based in Switzerland.
-------- Original Message --------
Subject: Re: [Pywps-dev] bonn workshop - pywps-demo back to work
Local Time: July 28, 2016 2:28 PM
UTC Time: July 28, 2016 12:28 PM
To: luis.de.sousa at protonmail.ch
CC: pywps-dev at lists.osgeo.org
Luis,
I'm working on this in jachym/pywps-4-demo and jachym/PyWPS branches 122_documentation, if you come to it,before I merge
looking forward to your feedback, let me know, once you have time to dig into this
Jachym
čt 28. 7. 2016 v 10:43 odesílatel Luís de Sousa <luis.de.sousa at protonmail.ch> napsal:
Hi everyone,
I have not found the time yet to look into this. I suggest you merge what have now. I will look into it the next few days.
Cheers,
Luís
Subject: [Pywps-dev] bonn workshop - pywps-demo back to work
Local Time: 24 July 2016 10:57 PM
UTC Time: 24 July 2016 20:57
To: pywps-dev at lists.osgeo.org
Hi all (and especially Luis),
I've started to dig into our documentation again [1], so we could be ready for the Bonn workshop [2].
Meanwhile, I've done two biggest changes:
1 - enabled relative directories for outputs and workdir from the configuration
2 - significantly simplified demo.py in pywps-demo - now it really seems to be working
I've created pull request for the demo - what do you think about it [3]?
Jachym
P.S. I'm counting with the work from Jan Rudolf for the REST API, therefore I removed all the related work from demo.py too
[1] https://github.com/geopython/pywps/issues/122
[2] https://github.com/geopython/pywps/pull/146
[3] https://github.com/geopython/pywps-demo/pull/14
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160801/09ca6543/attachment.html>
More information about the pywps-dev
