[Pywps-dev] bonn workshop - pywps-demo back to work
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Aug 1 14:25:40 PDT 2016
Thank you Luis,
I'm about co commit the documentation changes, so we could merge it soon
too - if you have time contribute, it should probably go into my branch
[1], so we could merge it in one step [2]
[1] https://github.com/jachym/pywps/tree/122_documentation
[2] https://github.com/geopython/pywps/pull/146
po 1. 8. 2016 v 23:21 odesílatel Jachym Cepicky <jachym.cepicky at gmail.com>
napsal:
> thank you Luis
> po 1. 8. 2016 v 20:50 odesílatel Luís de Sousa <
> luis.de.sousa at protonmail.ch> napsal:
>> Hi again,
>> I have the following set up running:
>> pywps: 4-beta1
>> pywps-demo: Jachym's fork
>> interpreter: python3
>> I was not able to get it running with Python2, but I am not so worried
>> with it. We just have to make sure everyone uses Python3.
>> I will do more testing tomorrow and then we could merge the demo project.
>> Cheers,
>> Luís
>> *Sent from ProtonMail <https://protonmail.ch>, encrypted email based in
>> Switzerland.*
>> -------- Original Message --------
>> Subject: Re: [Pywps-dev] bonn workshop - pywps-demo back to work
>> Local Time: August 1, 2016 12:54 PM
>> UTC Time: August 1, 2016 10:54 AM
>> From: luis.de.sousa at protonmail.ch
>> To: jachym.cepicky at gmail.com
>> CC: pywps-dev at lists.osgeo.org
>> Ok, I'll try that one. I tried the pywps-demo from the geopython
>> organisation this morning and it is not working.
>> One thing that bothers me: if something goes wrong before Flask is up
>> there is no way to tell what is happening (except debugging). The other day
>> I had a messed up GDAL version and the demo application would simply fail
>> without logging anything or issuing exceptions....
>> Luís
>> Switzerland.*
>> Local Time: July 28, 2016 2:28 PM
>> UTC Time: July 28, 2016 12:28 PM
>> From: jachym.cepicky at gmail.com
>> To: luis.de.sousa at protonmail.ch
>> Luis,
>> I'm working on this in jachym/pywps-4-demo and jachym/PyWPS branches
>> 122_documentation, if you come to it,before I merge
>> looking forward to your feedback, let me know, once you have time to dig
>> into this
>> Jachym
>> čt 28. 7. 2016 v 10:43 odesílatel Luís de Sousa <
>>> Hi everyone,
>>> I have not found the time yet to look into this. I suggest you merge
>>> what have now. I will look into it the next few days.
>>> Cheers,
>>> Luís
>>> Subject: [Pywps-dev] bonn workshop - pywps-demo back to work
>>> Local Time: 24 July 2016 10:57 PM
>>> UTC Time: 24 July 2016 20:57
>>> To: pywps-dev at lists.osgeo.org
>>> Hi all (and especially Luis),
>>> I've started to dig into our documentation again [1], so we could be
>>> ready for the Bonn workshop [2].
>>> Meanwhile, I've done two biggest changes:
>>> 1 - enabled relative directories for outputs and workdir from the
>>> configuration
>>> 2 - significantly simplified demo.py in pywps-demo - now it really seems
>>> to be working
>>> I've created pull request for the demo - what do you think about it [3]?
>>> Jachym
>>> P.S. I'm counting with the work from Jan Rudolf for the REST API,
>>> therefore I removed all the related work from demo.py too
>>> [1] https://github.com/geopython/pywps/issues/122
>>> [3] https://github.com/geopython/pywps-demo/pull/14
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160801/14c05741/attachment.html>
More information about the pywps-dev
