[Pywps-dev] bonn workshop - pywps-demo back to work
Jachym Cepicky jachym.cepicky at gmail.com
Mon Aug 1 14:22:14 PDT 2016
thank  you Luis
po 1. 8. 2016 v 20:50 odesílatel Luí­s de Sousa <luis.de.sousa at protonmail.ch>
napsal:
> Hi again,
> I have the following set up running:
> pywps: 4-beta1
> pywps-demo: Jachym's fork
> interpreter: python3
> I was not able to get it running with Python2, but I am not so worried
> with it. We just have to make sure everyone uses Python3.
> I will do more testing tomorrow and then we could merge the demo project.
> Cheers,
> Luís
> *Sent from ProtonMail <https://protonmail.ch>, encrypted email based in
> Switzerland.*
> -------- Original Message --------
> Subject: Re: [Pywps-dev] bonn workshop - pywps-demo back to work
> Local Time: August 1, 2016 12:54 PM
> UTC Time: August 1, 2016 10:54 AM
> From: luis.de.sousa at protonmail.ch
> To: jachym.cepicky at gmail.com
> CC: pywps-dev at lists.osgeo.org
> Ok, I'll try that one. I tried the pywps-demo from the geopython
> organisation this morning and it is not working.
> One thing that bothers me: if something goes wrong before Flask is up
> there is no way to tell what is happening (except debugging). The other day
> I had a messed up GDAL version and the demo application would simply fail
> without logging anything or issuing exceptions....
> Luís
> Switzerland.*
> Local Time: July 28, 2016 2:28 PM
> UTC Time: July 28, 2016 12:28 PM
> From: jachym.cepicky at gmail.com
> To: luis.de.sousa at protonmail.ch
> Luis,
> I'm working on this in jachym/pywps-4-demo and jachym/PyWPS branches
> 122_documentation, if you come to it,before I merge
> looking forward to your feedback, let me know, once you have time to dig
> into this
> Jachym
> čt 28. 7. 2016 v 10:43 odesílatel Luí­s de Sousa <
> luis.de.sousa at protonmail.ch> napsal:
>> Hi everyone,
>> I have not found the time yet to look into this. I suggest you merge what
>> have now. I will look into it the next few days.
>> Cheers,
>> Luís
>> Subject: [Pywps-dev] bonn workshop - pywps-demo back to work
>> Local Time: 24 July 2016 10:57 PM
>> UTC Time: 24 July 2016 20:57
>> To: pywps-dev at lists.osgeo.org
>> Hi all (and especially Luis),
>> I've started to dig into our documentation again [1], so we could be
>> ready for the Bonn workshop [2].
>> Meanwhile, I've done two biggest changes:
>> 1 - enabled relative directories for outputs and workdir from the
>> configuration
>> 2 - significantly simplified demo.py in pywps-demo - now it really seems
>> to be working
>> I've created pull request for the demo - what do you think about it [3]?
>> Jachym
>> P.S. I'm counting with the work from Jan Rudolf for the REST API,
>> therefore I removed all the related work from demo.py too
>> [1] https://github.com/geopython/pywps/issues/122
>> [2] https://github.com/geopython/pywps/pull/146
>> [3] https://github.com/geopython/pywps-demo/pull/14
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160801/fec53131/attachment.html>
More information about the pywps-dev mailing list
