[Pywps-dev] process discovery
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Aug 8 12:37:57 PDT 2016
hi all,
I'll try to reimplement - as metioned - I think, the right place to do this
is in the "pywps-demo" repo (or at least as an example in documentation)
however, last time I was atempting to implement this feature, I faced some
issues regarding apache variables export and wsgi
will let you know
i hope, you like at least the "simple" version of the wsgi script, as
proposed in my jachym/pywps/122_documentation branch
https://github.com/jachym/PyWPS/blob/122_documentation/wsgi/pywps.wsgi
so, basically, all you want is to replace 6 to 22 with
cfg = os.env['PYWPS_CFG']
processes = pywps.utils.processes_from_dir(os.env['PYWPS_PROCESSES'])
and it should work, right?
J
st 3. 8. 2016 v 21:02 odesílatel Jonas Eberle <jonas.eberle at gmx.de> napsal:
> Hi all,
> I second this request as I like the way to store processes in a directory
> as we did in PyWPS 3 and not touching the wsgi file for any new process.
> Cheers,
> Jonas
> ----- Am 3. Aug 2016 um 20:28 schrieb Tom Kralidis <tomkralidis at gmail.com
> Hi Luís: consider this PyWPS 4 based application wrapper:
> https://github.com/geopython/demo.pywps.org/blob/master/PyWPS/wps.wsgi.
> I specifically have to call out the processes when initializing the
> application, i.e.:
> from pywps.app import Service
> from cite.processes import HelloWorld
> os.environ['PYWPS_CFG'] = 'cite/cite.cfg'
> application = Service(processes=[HelloWorld()])
> I would much rather do:
> os.environ['PYWPS_PROCESSES'] = '/path/to/a/dir/of/processes' # or
> this could also be specified in the configuration if desired
> application = Service() # PYWPS_CFG and PYWPS_PROCESSES drive the
> application
> This way I don't have to update any application code if I add
> processes via some other workflow. In addition, I can use this single
> WSGI file setup and have, say, Apache settings like:
> WSGIScriptAlias /wps1 /osgeo/demo.pycsw.org/pycsw/csw.wsgi
> WSGIScriptAlias /wps2 /osgeo/demo.pycsw.org/pycsw/csw.wsgi
> WSGIScriptAlias /wps1000 /osgeo/demo.pycsw.org/pycsw/csw.wsgi
> SetEnvIf Request_URI "/wps1" PYCSW_CONFIG=/path/to/wps1.cfg
> SetEnvIf Request_URI "/wps2" PYCSW_CONFIG=/path/to/wps2.cfg
> SetEnvIf Request_URI "/wps1000" PYCSW_CONFIG=/path/to/wps1000.cfg
> Hope this helps clarify things?
> ..Tom
> On Wed, Aug 3, 2016 at 3:00 AM, Luís de Sousa
> <luis.de.sousa at protonmail.ch> wrote:
> > Tom,
> > I am not sure I entirely understand this. What do you mean by "mapping
> > endpoints"?
> > PyWPS-4 is now just a library, or an API, if you will. It is totally
> > insulated from web server aspects. On a first glance, these scalability
> > issues must be solved at application level.
> > Cheers,
> > Luís
> > -------- Original Message --------
> > Subject: Re: [Pywps-dev] process discovery
> > Local Time: 2 August 2016 10:58 PM
> > UTC Time: 2 August 2016 20:58
> > From: tomkralidis at gmail.com
> > To: pywps-dev at lists.osgeo.org
> > All: as per today's PSC meeting bringing this thread up again.
> > Per below, a great feature of PyWPS 3 is multi-tenancy against
> > a single deployment. For example, I can have a single WSGI
> > wrapper along with environ['PYWPS_CFG'] and
> > environ['PYWPS_PROCESSES'] as part of the process.
> > This, in combination with mapping endpoints to environment
> > variables allows PyWPS to scale with 1..n WPS endpoints which
> > use the same single WSGI wrapper. One can have 1000 PyWPS
> > configuration files and this approach scales accordingly. As
> > well, one can scale processes on a single server with the same
> > approach.
> > Unless I am mistaken (which is quite possible) it appears that
> > PyWPS master/moving forward to PyWPS 4 requires that a
> > simple wrapper explicitly define processes [1].
> > Is there another way to accomplish the pluggable features
> > of PyWPS 3 currently?
> > [1] https://github.com/geopython/pywps-demo/blob/master/demo.py#L60
> >>> Subject: [Pywps-dev] process discovery
> >>> Local Time: March 4, 2016 1:20 AM
> >>> UTC Time: March 4, 2016 1:20 AM
> >>> Hi all: I'm setting up http://demo.pywps.org as a demo space to
> >>> serve PyWPS instances as required. The goal here is a minimal
> >>> configuration (assuming a PyWPS install), along with some Apache
> >>> setup.
> >>> In PyWPS 3, there was functionality to define a PYWPS_PROCESSES
> >>> environment variable. There was also the ability to define this in the
> >>> PyWPS
> >>> config. Looks like this is not available in master branch
> >>> anymore.
> >>> Any plans on adding this back in the codebase? The value here is being
> >>> able to deploy a single WPS (in my case WSGI) wrapper which operates
> >>> against multiple configurations and processes setups driven by a given
> >>> endpoint.
> >>> Or is there another/better way to acheive this?
> >>> ..Tom
> >>> _______________________________________________
> >>> pywps-dev mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160808/7f84beb1/attachment.html>
More information about the pywps-dev
