[Pywps-dev] process discovery
Tom Kralidis
tomkralidis at gmail.com
Thu Aug 11 20:00:57 PDT 2016
Hi Jachym: I think this looks like what we're looking for, right Jonas?
On Mon, Aug 8, 2016 at 3:37 PM, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> hi all,
> I'll try to reimplement - as metioned - I think, the right place to do this
> is in the "pywps-demo" repo (or at least as an example in documentation)
> however, last time I was atempting to implement this feature, I faced some
> issues regarding apache variables export and wsgi
> will let you know
> i hope, you like at least the "simple" version of the wsgi script, as
> proposed in my jachym/pywps/122_documentation branch
> https://github.com/jachym/PyWPS/blob/122_documentation/wsgi/pywps.wsgi
> so, basically, all you want is to replace 6 to 22 with
> cfg = os.env['PYWPS_CFG']
> processes = pywps.utils.processes_from_dir(os.env['PYWPS_PROCESSES'])
> and it should work, right?
> J
> st 3. 8. 2016 v 21:02 odesílatel Jonas Eberle <jonas.eberle at gmx.de> napsal:
>> Hi all,
>> I second this request as I like the way to store processes in a directory
>> as we did in PyWPS 3 and not touching the wsgi file for any new process.
>> Cheers,
>> Jonas
>> ----- Am 3. Aug 2016 um 20:28 schrieb Tom Kralidis
>> <tomkralidis at gmail.com>:
>> Hi Luís: consider this PyWPS 4 based application wrapper:
>> https://github.com/geopython/demo.pywps.org/blob/master/PyWPS/wps.wsgi.
>> I specifically have to call out the processes when initializing the
>> application, i.e.:
>> from pywps.app import Service
>> from cite.processes import HelloWorld
>> os.environ['PYWPS_CFG'] = 'cite/cite.cfg'
>> application = Service(processes=[HelloWorld()])
>> I would much rather do:
>> os.environ['PYWPS_PROCESSES'] = '/path/to/a/dir/of/processes' # or
>> this could also be specified in the configuration if desired
>> application = Service() # PYWPS_CFG and PYWPS_PROCESSES drive the
>> application
>> This way I don't have to update any application code if I add
>> processes via some other workflow. In addition, I can use this single
>> WSGI file setup and have, say, Apache settings like:
>> WSGIScriptAlias /wps1 /osgeo/demo.pycsw.org/pycsw/csw.wsgi
>> WSGIScriptAlias /wps2 /osgeo/demo.pycsw.org/pycsw/csw.wsgi
>> WSGIScriptAlias /wps1000 /osgeo/demo.pycsw.org/pycsw/csw.wsgi
>> SetEnvIf Request_URI "/wps1" PYCSW_CONFIG=/path/to/wps1.cfg
>> SetEnvIf Request_URI "/wps2" PYCSW_CONFIG=/path/to/wps2.cfg
>> SetEnvIf Request_URI "/wps1000" PYCSW_CONFIG=/path/to/wps1000.cfg
>> Hope this helps clarify things?
>> ..Tom
>> On Wed, Aug 3, 2016 at 3:00 AM, Luís de Sousa
>> <luis.de.sousa at protonmail.ch> wrote:
>> > Tom,
>> > I am not sure I entirely understand this. What do you mean by "mapping
>> > endpoints"?
>> > PyWPS-4 is now just a library, or an API, if you will. It is totally
>> > insulated from web server aspects. On a first glance, these scalability
>> > issues must be solved at application level.
>> > Cheers,
>> > Luís
>> > -------- Original Message --------
>> > Subject: Re: [Pywps-dev] process discovery
>> > Local Time: 2 August 2016 10:58 PM
>> > UTC Time: 2 August 2016 20:58
>> > From: tomkralidis at gmail.com
>> > To: pywps-dev at lists.osgeo.org
>> > All: as per today's PSC meeting bringing this thread up again.
>> > Per below, a great feature of PyWPS 3 is multi-tenancy against
>> > a single deployment. For example, I can have a single WSGI
>> > wrapper along with environ['PYWPS_CFG'] and
>> > environ['PYWPS_PROCESSES'] as part of the process.
>> > This, in combination with mapping endpoints to environment
>> > variables allows PyWPS to scale with 1..n WPS endpoints which
>> > use the same single WSGI wrapper. One can have 1000 PyWPS
>> > configuration files and this approach scales accordingly. As
>> > well, one can scale processes on a single server with the same
>> > approach.
>> > Unless I am mistaken (which is quite possible) it appears that
>> > PyWPS master/moving forward to PyWPS 4 requires that a
>> > simple wrapper explicitly define processes [1].
>> > Is there another way to accomplish the pluggable features
>> > of PyWPS 3 currently?
>> > [1] https://github.com/geopython/pywps-demo/blob/master/demo.py#L60
>> >>> Subject: [Pywps-dev] process discovery
>> >>> Local Time: March 4, 2016 1:20 AM
>> >>> UTC Time: March 4, 2016 1:20 AM
>> >>> Hi all: I'm setting up http://demo.pywps.org as a demo space to
>> >>> serve PyWPS instances as required. The goal here is a minimal
>> >>> configuration (assuming a PyWPS install), along with some Apache
>> >>> setup.
>> >>> In PyWPS 3, there was functionality to define a PYWPS_PROCESSES
>> >>> environment variable. There was also the ability to define this in the
>> >>> PyWPS
>> >>> config. Looks like this is not available in master branch
>> >>> anymore.
>> >>> Any plans on adding this back in the codebase? The value here is being
>> >>> able to deploy a single WPS (in my case WSGI) wrapper which operates
>> >>> against multiple configurations and processes setups driven by a given
>> >>> endpoint.
>> >>> Or is there another/better way to acheive this?
>> >>> ..Tom
>> >>> _______________________________________________
>> >>> pywps-dev mailing list
>> >>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev
