[Pywps-dev] PyWPS testing
Jachym Cepicky
jachym.cepicky at gmail.com
Sun Aug 21 05:13:48 PDT 2016
Hi Jonas,
I've implemented your fixes to mine branch [1]
should be part of the latest pull request [2]
[1]
https://github.com/jachym/PyWPS/commit/292231257e234ba3e6b9b17a6e0ae47d135ac6e6
[2] https://github.com/geopython/pywps/pull/155
J
pá 19. 8. 2016 v 9:11 odesílatel Jachym Cepicky <jachym.cepicky at gmail.com>
napsal:
> Jonas,
> big thanks - some of those issues, I've fixed somewhere else, those
> slipped through my eyes or I did it wrong
> can you please make pull request and merge?
> J
> čt 18. 8. 2016 v 21:46 odesílatel Jonas Eberle <jonas.eberle at gmx.de>
> napsal:
>> Hi all,
>> I discovered some issues when testing the current master repository:
>> 1) Python error (no such file or directory because working directory has
>> been cleaned up already before) when storing output data as reference with
>> synchronous execution. As a solution I added the variable "async" to
>> Process and extended the if clause in line 244 (app/Process.py):
>> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-bddcbbd3f8d8f4182a33f03a1f9a847dR245
>> 2) Output url in inout/storage.py is not a combination of "url" and
>> "outputurl", only "outputurl" from configuration is used:
>> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-12acb511d79bad7767468cd036926743R76
>> 3) The calculation of available space on disk was wrong, for Linux
>> systems the method "get_free_space" delivers the number of free
>> blocks (inout/storage.py)
>> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-12acb511d79bad7767468cd036926743R87
>> 4) The output format class has no method "get_extension"
>> (inout/storage.py), thus I used just the extension attribute:
>> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-12acb511d79bad7767468cd036926743R98
>> Best regards,
>> Jonas
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160821/e28d70c7/attachment.html>
More information about the pywps-dev
