[Pywps-dev] PyWPS testing
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Aug 19 00:11:09 PDT 2016
Jonas,
big thanks - some of those issues, I've fixed somewhere else, those slipped
through my eyes or I did it wrong
can you please make pull request and merge?
J
čt 18. 8. 2016 v 21:46 odesílatel Jonas Eberle <jonas.eberle at gmx.de> napsal:
> Hi all,
> I discovered some issues when testing the current master repository:
> 1) Python error (no such file or directory because working directory has
> been cleaned up already before) when storing output data as reference with
> synchronous execution. As a solution I added the variable "async" to
> Process and extended the if clause in line 244 (app/Process.py):
> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-bddcbbd3f8d8f4182a33f03a1f9a847dR245
> 2) Output url in inout/storage.py is not a combination of "url" and
> "outputurl", only "outputurl" from configuration is used:
> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-12acb511d79bad7767468cd036926743R76
> 3) The calculation of available space on disk was wrong, for Linux systems
> the method "get_free_space" delivers the number of free
> blocks (inout/storage.py)
> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-12acb511d79bad7767468cd036926743R87
> 4) The output format class has no method "get_extension"
> (inout/storage.py), thus I used just the extension attribute:
> https://github.com/jonas-eberle/pywps/commit/51338260674b7271246cc617ff2c37482ec86080#diff-12acb511d79bad7767468cd036926743R98
> Best regards,
> Jonas
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160819/7968baea/attachment-0001.html>
More information about the pywps-dev
