[Pywps-dev] development workflow update
Tom Kralidis tomkralidis at gmail.com
Thu Feb 11 04:30:24 PST 2016
Hi Luís: good question.  IMHO keeping both under the same repostory
makes sense from a project viability perspective:
- we are in OSGeo incubation for 3. Doing a merge now keeps the
   project straight / clean over time
- since the incubation started in 3, it is not clear if the
   application will be valid after rewriting the software, dump the old
   code base and starting from scratch.  Having said this, 4 will have to
   to be mature, which takes time, with lots of deployments and community
   behind it
- there is already a considerable community around 3 so let's leverage
   that existing community
- the licensing change and rewrite between PyWPS 3 and 4 does not present
   any complications
- packaging management becomes much easier along a single path
..Tom
On Thu, 11 Feb 2016, Luís de Sousa wrote:
> Date: Thu, 11 Feb 2016 08:44:25 +0100
> From: Luís de Sousa <luis.a.de.sousa at gmail.com>
> To: Tom Kralidis <tomkralidis at gmail.com>
> Cc: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
> Subject: Re: [Pywps-dev] development workflow update
> Hi there Tom,
> What are the advantages of merging the two git projects? It seems far
> simpler to keep versions 3 and 4 separated.
> Luís
> On 11 February 2016 at 02:37, Tom Kralidis <tomkralidis at gmail.com> wrote:
>> More thoughts:
>> Given current master and pywps-4 branches have totally different
>> commit histories, it is not possible to simply merge pywps-4 into
>> master via GitHub pull request.  One option we could consider is using
>> the "ours" merge strategy:
>> git checkout pywps-4
>> git merge -s ours master
>> git checkout master
>> git merge pywps-4
>> git push -f origin master
>> This essentially pushes pywps-4 into master branch without wiping out
>> master branch history.
>> ..Tom
>> On Tue, Feb 9, 2016 at 4:28 PM, Tom Kralidis <tomkralidis at gmail.com> wrote:
>>> Hi all: FYI the following have been completed
>>> against https://github.com/geopython/pywps:
>>> - master branch is up to date
>>> - issues / milestones are up to date and represent 3.x and 4.x plans
>>> - branch pywps-4 represents our PyWPS 4 effort
>>> - branch pywps-3.2 represents our 3.x development.  At this point in time
>>> any
>>>   fixes in master that apply to 3.x should be also applied to branch
>>> pywps-3.2
>>> - any further 3.x releases are to built/tagged/released off branch pywps-3.2
>>> At some point branch pywps-4 will be merged as master and pywps-3.2 will be
>>> our 3.x support branch.  From that point forward, any changes in master
>>> should _not_ be applied to branch pywps-3.2 given the backward
>>> compability break.
>>> I'd like to hear thoughts on pywps-4 -> master efforts and when folks
>>> think is a good time to move that over.  The idea here is that we have
>>> supported releases (3.2.3) to download or pip install, and master
>>> represents development.  Does anyone have any knowledge that master
>>> is being used operationally anywhere (which is a bad idea given it's
>>> not a release).
>>> Cheers
>>> ..Tom
>> pywps-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
