[Pywps-dev] development workflow update
Luís de Sousa luis.a.de.sousa at gmail.com
Thu Feb 11 10:51:49 PST 2016
Hi Tom,
I understand your points; the ours strategy looks appropriate.
Luís
On 11 February 2016 at 13:30, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi Luís: good question.  IMHO keeping both under the same repostory
> makes sense from a project viability perspective:
> - we are in OSGeo incubation for 3. Doing a merge now keeps the
>   project straight / clean over time
> - since the incubation started in 3, it is not clear if the
>   application will be valid after rewriting the software, dump the old
>   code base and starting from scratch.  Having said this, 4 will have to
>   to be mature, which takes time, with lots of deployments and community
>   behind it
> - there is already a considerable community around 3 so let's leverage
>   that existing community
> - the licensing change and rewrite between PyWPS 3 and 4 does not present
>   any complications
> - packaging management becomes much easier along a single path
> ..Tom
> On Thu, 11 Feb 2016, Luís de Sousa wrote:
>> Date: Thu, 11 Feb 2016 08:44:25 +0100
>> From: Luís de Sousa <luis.a.de.sousa at gmail.com>
>> To: Tom Kralidis <tomkralidis at gmail.com>
>> Cc: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
>> Subject: Re: [Pywps-dev] development workflow update
>> Hi there Tom,
>> What are the advantages of merging the two git projects? It seems far
>> simpler to keep versions 3 and 4 separated.
>> Luís
>> On 11 February 2016 at 02:37, Tom Kralidis <tomkralidis at gmail.com> wrote:
>>> More thoughts:
>>> Given current master and pywps-4 branches have totally different
>>> commit histories, it is not possible to simply merge pywps-4 into
>>> master via GitHub pull request.  One option we could consider is using
>>> the "ours" merge strategy:
>>> git checkout pywps-4
>>> git merge -s ours master
>>> git checkout master
>>> git merge pywps-4
>>> git push -f origin master
>>> This essentially pushes pywps-4 into master branch without wiping out
>>> master branch history.
>>> ..Tom
>>> On Tue, Feb 9, 2016 at 4:28 PM, Tom Kralidis <tomkralidis at gmail.com>
>>> wrote:
>>>> Hi all: FYI the following have been completed
>>>> against https://github.com/geopython/pywps:
>>>> - master branch is up to date
>>>> - issues / milestones are up to date and represent 3.x and 4.x plans
>>>> - branch pywps-4 represents our PyWPS 4 effort
>>>> - branch pywps-3.2 represents our 3.x development.  At this point in
>>>> time
>>>> any
>>>>   fixes in master that apply to 3.x should be also applied to branch
>>>> pywps-3.2
>>>> - any further 3.x releases are to built/tagged/released off branch
>>>> pywps-3.2
>>>> At some point branch pywps-4 will be merged as master and pywps-3.2 will
>>>> be
>>>> our 3.x support branch.  From that point forward, any changes in master
>>>> should _not_ be applied to branch pywps-3.2 given the backward
>>>> compability break.
>>>> I'd like to hear thoughts on pywps-4 -> master efforts and when folks
>>>> think is a good time to move that over.  The idea here is that we have
>>>> supported releases (3.2.3) to download or pip install, and master
>>>> represents development.  Does anyone have any knowledge that master
>>>> is being used operationally anywhere (which is a bad idea given it's
>>>> not a release).
>>>> Cheers
>>>> ..Tom
>>> pywps-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
