[Pywps-dev] execute not working well?
Jachym Cepicky
jachym.cepicky at gmail.com
Sat Feb 13 23:39:55 PST 2016
thanks
út 9. 2. 2016 v 8:17 odesílatel Luís de Sousa <luis.a.de.sousa at gmail.com>
napsal:
> Hi Pablo,
> There is indeed a small glitch in that process, output2 is being
> calculated with input1. Thanks for reporting. Why don't you try to
> correct it yourself? It is a good way of getting acquainted with the
> code.
> In the meantime, I have created a pull request correcting it at GitHub:
> https://github.com/geopython/pywps/pull/51
> Cheers,
> Luís
> On 9 February 2016 at 02:20, pablo zader <pzader at gmail.com> wrote:
> > Hi lista
> > I'm trying this query:
> http://localhost/cgi-bin/wps.py?&service=wps&version=1.0.0&request=execute&identifier=dummyprocess&datainputs=input2=200;input1=100
> > but the result is not as expected, just add one and subtract one (the
> > default).
> > <wps:Status creationTime="2016-02-08T22:17:59Z">
> > <wps:ProcessSucceeded>PyWPS Process dummyprocess successfully
> > calculated</wps:ProcessSucceeded>
> > </wps:Status>
> > <wps:ProcessOutputs>
> > <wps:Output>
> > <ows:Identifier>output2</ows:Identifier>
> > <ows:Title>Output2 subtract 1 result</ows:Title>
> > <wps:Data>
> > <wps:LiteralData dataType="integer">99</wps:LiteralData>
> > </wps:Data>
> > </wps:Output>
> > <wps:Output>
> > <ows:Identifier>output1</ows:Identifier>
> > <ows:Title>Output1 add 1 result</ows:Title>
> > <wps:Data>
> > <wps:LiteralData dataType="integer">101</wps:LiteralData>
> > </wps:Data>
> > </wps:Output>
> > </wps:ProcessOutputs>
> > </wps:ExecuteResponse>
> > </soap:Body>
> > </soap:Envelope>
> > Where is the problem?
> > Thanks in advanced
> > Pablo
> > pywps-dev mailing list
> > pywps-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160214/7a58ec4d/attachment.html>
More information about the pywps-dev
