[Pywps-dev] development workflow update
Jachym Cepicky jachym.cepicky at gmail.com
Sun Feb 14 00:01:39 PST 2016
HI Tom,
thanks for summarising the topic
I was always saying: we should put stable release to master.
But I think,  .. pywps-4 is now in "good enough" shape, so it can be put to
master branch.
Anybody who uses "master" should be on the mailing list, so no big surprise
should occur, when the big bang happens.
so from my perspective: any time now :)
J
čt 11. 2. 2016 v 21:29 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> Thanks Luís.  FYI I've tested this approach against my fork for an idea:
> https://github.com/tomkralidis/pywps
> Here is the commit history:
> https://github.com/tomkralidis/pywps/commits/master
> Note that last push is the action that updates master.
> As well, I would push a backup copy of master called master-old before
> merging just in case.
> Thoughts on moving forward?  To recap, propose pywps-4 branch to become
> the new master branch and branch pywps-3.2 is our 3.x support.
> ..Tom
> On Thu, 11 Feb 2016, Luís de Sousa wrote:
> > Date: Thu, 11 Feb 2016 19:51:49 +0100
> > From: Luís de Sousa <luis.a.de.sousa at gmail.com>
> > To: Tom Kralidis <tomkralidis at gmail.com>
> > Cc: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
> > Subject: Re: [Pywps-dev] development workflow update
> > Hi Tom,
> > I understand your points; the ours strategy looks appropriate.
> > Luís
> > On 11 February 2016 at 13:30, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
> >> Hi Luís: good question.  IMHO keeping both under the same repostory
> >> makes sense from a project viability perspective:
> >> - we are in OSGeo incubation for 3. Doing a merge now keeps the
> >>   project straight / clean over time
> >> - since the incubation started in 3, it is not clear if the
> >>   application will be valid after rewriting the software, dump the old
> >>   code base and starting from scratch.  Having said this, 4 will have to
> >>   to be mature, which takes time, with lots of deployments and community
> >>   behind it
> >> - there is already a considerable community around 3 so let's leverage
> >>   that existing community
> >> - the licensing change and rewrite between PyWPS 3 and 4 does not
> present
> >>   any complications
> >> - packaging management becomes much easier along a single path
> >> ..Tom
> >>> Date: Thu, 11 Feb 2016 08:44:25 +0100
> >>> Hi there Tom,
> >>> What are the advantages of merging the two git projects? It seems far
> >>> simpler to keep versions 3 and 4 separated.
> >>> Luís
> >>> On 11 February 2016 at 02:37, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
> >>>> More thoughts:
> >>>> Given current master and pywps-4 branches have totally different
> >>>> commit histories, it is not possible to simply merge pywps-4 into
> >>>> master via GitHub pull request.  One option we could consider is using
> >>>> the "ours" merge strategy:
> >>>> git checkout pywps-4
> >>>> git merge -s ours master
> >>>> git checkout master
> >>>> git merge pywps-4
> >>>> git push -f origin master
> >>>> This essentially pushes pywps-4 into master branch without wiping out
> >>>> master branch history.
> >>>> ..Tom
> >>>> On Tue, Feb 9, 2016 at 4:28 PM, Tom Kralidis <tomkralidis at gmail.com>
> >>>> wrote:
> >>>>> Hi all: FYI the following have been completed
> >>>>> against https://github.com/geopython/pywps:
> >>>>> - master branch is up to date
> >>>>> - issues / milestones are up to date and represent 3.x and 4.x plans
> >>>>> - branch pywps-4 represents our PyWPS 4 effort
> >>>>> - branch pywps-3.2 represents our 3.x development.  At this point in
> >>>>> time
> >>>>> any
> >>>>>   fixes in master that apply to 3.x should be also applied to branch
> >>>>> pywps-3.2
> >>>>> - any further 3.x releases are to built/tagged/released off branch
> >>>>> pywps-3.2
> >>>>> At some point branch pywps-4 will be merged as master and pywps-3.2
> will
> >>>>> be
> >>>>> our 3.x support branch.  From that point forward, any changes in
> master
> >>>>> should _not_ be applied to branch pywps-3.2 given the backward
> >>>>> compability break.
> >>>>> I'd like to hear thoughts on pywps-4 -> master efforts and when folks
> >>>>> think is a good time to move that over.  The idea here is that we
> have
> >>>>> supported releases (3.2.3) to download or pip install, and master
> >>>>> represents development.  Does anyone have any knowledge that master
> >>>>> is being used operationally anywhere (which is a bad idea given it's
> >>>>> not a release).
> >>>>> Cheers
> >>>>> ..Tom
> >>>> _______________________________________________
> >>>> pywps-dev mailing list
> >>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160214/7a48d8cf/attachment.html>
More information about the pywps-dev mailing list
