[Pywps-dev] tests execution in 3.2 branch
Tom Kralidis tomkralidis at gmail.com
Thu Feb 18 03:45:16 PST 2016
Diky Jachym: I had thoughts of bringing these to life and hooking up
to Travis-CI (currently only master branch is tested by Travis-CI),
however efforts are probably best put into master branch moving
forward.
..Tom
On Thu, Feb 18, 2016 at 5:17 AM, Jachym Cepicky
<jachym.cepicky at gmail.com> wrote:
> Hi,
> that has been a long time ago, when we setup it, without basic knowledge
> about unittesting :-(
> AFAIK, you had to run each script manually (there was no central point)
> It works for tests/benchmark.py - others seem to be broken :-/
> J
> st 17. 2. 2016 v 23:59 odesílatel Tom Kralidis <tomkralidis at gmail.com>
> napsal:
>> Hi all: in branch pywps-3.2 [1], how does one run all the tests in [2]?
>> Running `python -m unittests tests` results in:
>> ImportError: No module named tests
>> Any suggestions?
>> Cheers
>> ..Tom
>> [1] https://github.com/geopython/pywps/tree/pywps-3.2
>> [2] https://github.com/geopython/pywps/tree/pywps-3.2/tests
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
