[Pywps-dev] tests execution in 3.2 branch
Jachym Cepicky jachym.cepicky at gmail.com
Thu Feb 18 03:54:31 PST 2016
yah, we could reuse at least integration tests used in pywps-4-demo
čt 18. 2. 2016 v 12:45 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> Diky Jachym: I had thoughts of bringing these to life and hooking up
> to Travis-CI (currently only master branch is tested by Travis-CI),
> however efforts are probably best put into master branch moving
> forward.
> ..Tom
> On Thu, Feb 18, 2016 at 5:17 AM, Jachym Cepicky
> <jachym.cepicky at gmail.com> wrote:
> > Hi,
> > that has been a long time ago, when we setup it, without basic knowledge
> > about unittesting :-(
> > AFAIK, you had to run each script manually (there was no central point)
> > It works for tests/benchmark.py - others seem to be broken :-/
> > J
> > st 17. 2. 2016 v 23:59 odesílatel Tom Kralidis <tomkralidis at gmail.com>
> > napsal:
> >> Hi all: in branch pywps-3.2 [1], how does one run all the tests in [2]?
> >> Running `python -m unittests tests` results in:
> >> ImportError: No module named tests
> >> Any suggestions?
> >> Cheers
> >> ..Tom
> >> [1] https://github.com/geopython/pywps/tree/pywps-3.2
> >> [2] https://github.com/geopython/pywps/tree/pywps-3.2/tests
> >> _______________________________________________
> >> pywps-dev mailing list
> >> pywps-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160218/9c670f63/attachment.html>
More information about the pywps-dev mailing list
