[Pywps-dev] [GSOC] First documentation attempt
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Jul 15 23:38:10 PDT 2016
Hi Jan,
I finally went through this documentation. Several notes do I have:
1 - Could you please add it to your repository to docs/ directory in RST
format ?
2 - You are using some scripts and pre-configured configuration file (like
the one for the apache2 server) - could you add chapter "configuring
apache2 wsgi for PyWPS" so that advanced server administrators could just
copy&paste the configuration from your example to their server and could go
on? I doubt, they will start with new server configuration - it's totally
handy to have it in place, but the documentation should be more verbose
3 - Same applies to the database user - I doubt, you will need to create
new user on operating system level - it should be sufficient, if you create
the user in database and in pg_hba.conf you enable connection to the
database using password and login
4 - you can use $USER environment variable instead of "user" keyword in
chmod
5 - you can set group and user in once step: chown www-data:www-data -R
/dir/
6 - instead of calling "nano" directly, you can use $EDITOR environment
variable - it's more generic, will work and will work for everybody
I hope, it's clear - good work with the documentation, this should just
help to make it better
Jachym
pá 24. 6. 2016 v 0:25 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz> napsal:
> Hello,
> I tried to describe, how to install my forked PyWPS on Ubuntu with Apache
> and PostgreSQL. It's here http://gsoc-2016.jan-rudolf.cz/ubuntu-deployment,
> please try it and let me known any ideas. I will change description
> according to my development on the project. I know, that there is a space
> for enhancement (for example last steps with database tables, some files
> position...), I will work on it.
> Cheers, Jan
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160716/3617ba80/attachment.html>
More information about the pywps-dev
