[Pywps-dev] [GSOC] First documentation attempt
Jan Rudolf
rudolja1 at fit.cvut.cz
Sat Jul 16 21:45:15 PDT 2016
Thanks, I will look on it on Monday too.
On 2016-07-16 08:38, Jachym Cepicky wrote:
> Hi Jan,
> I finally went through this documentation. Several notes do I have:
> 1 - Could you please add it to your repository to docs/ directory in
> RST format ?
> 2 - You are using some scripts and pre-configured configuration file
> (like the one for the apache2 server) - could you add chapter
> "configuring apache2 wsgi for PyWPS" so that advanced server
> administrators could just copy&paste the configuration from your
> example to their server and could go on? I doubt, they will start with
> new server configuration - it's totally handy to have it in place, but
> the documentation should be more verbose
> 3 - Same applies to the database user - I doubt, you will need to
> create new user on operating system level - it should be sufficient,
> if you create the user in database and in pg_hba.conf you enable
> connection to the database using password and login
> 4 - you can use $USER environment variable instead of "user" keyword
> in chmod
> 5 - you can set group and user in once step: chown www-data:www-data
> -R /dir/
> 6 - instead of calling "nano" directly, you can use $EDITOR
> environment variable - it's more generic, will work and will work for
> everybody
> I hope, it's clear - good work with the documentation, this should
> just help to make it better
> Jachym
> pá 24. 6. 2016 v 0:25 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz>
> napsal:
>> Hello,
>> I tried to describe, how to install my forked PyWPS on Ubuntu with
>> Apache and PostgreSQL. It's here
>> http://gsoc-2016.jan-rudolf.cz/ubuntu-deployment, please try it and
>> let me known any ideas. I will change description according to my
>> development on the project. I know, that there is a space for
>> enhancement (for example last steps with database tables, some files
>> position...), I will work on it.
>> Cheers, Jan _______________________________________________
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev
