[Pywps-dev] PyWPS Installation
Jan Rudolf
rudolja1 at fit.cvut.cz
Wed Jun 8 03:48:44 PDT 2016
Another idea came to my mind - if do files of downloaded PyWPS have
owner permissions for your user account. I tried quick installation on
Ubuntu (I use Mac OS) and my steps were this:
sudo apt-get install pip python-gdal
sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev (I
had problem with installation od lxml, xslt and zlib are probably
redundant)
- create virtualenv and activated it, in the virtualenv
git clone https://github.com/jan-rudolf/pywps
pip install -r requirements.txt
python setup.py install
- quick test (no output is success)
python -c "import pywps"
and it works too.
Good luck, Jan
> On 2016-06-08 11:39, Vikas Mishra wrote:
>> Hi Jan,
>> Yes the virtualenv is activated and I tried running "python setup.py
>> install" without the sudo command so that it calls the python
>> interpreter of the Virtualenv but it gives me a Permission denied
>> error "Permissions Denied: 'pywps.egg-info/requires.tx' " Actually
>> that's the main issue am not able to install pywps in virtualenv, it
>> gives permission error when I don't use sudo, and the moment I run the
>> command with sudo it installs pywps globally.
>> Vikas Mishra
>> MSc(Hons) Economics + B.E. Electronics and Electrical Engineering
>> BIRLA INSTITUTE OF TECHNOLOGY & SCIENCE, Pilani
>> KK Birla Goa Campus
>> 8412898899|vikasmishra95 at gmail.com
>> On Wed, Jun 8, 2016 at 11:22 AM, Jan Rudolf <rudolja1 at fit.cvut.cz>
>> wrote:
>>> Hi Vikas,
>>>> So When I am inside the virtualenv and install the dependencies
>>> they
>>>> get installed locally (inside virtualenv and not globally) but
>>> when I
>>>> do 'sudo pip setup.py install' this installs pywps globally hence
>>> when
>>>> I try to run demo.py from inside the virtualenv it gives an import
>>>> error that It can't import pywps.
>>> Did you have Virtualenv activated? Then should the "python" command
>>> call
>>> the Python interpreter of your Virtualenv, so then if you use
>>> "python
>>> setup.py install", it should install PyWPS into Virtualenv's Python.
>>> It's work for me. Hope it help.
>>> Jan
>>> On 2016-06-08 09:41, Vikas Mishra wrote:
>>>> Hi,
>>>> I finally figured out the reason why I was getting import error
>>> when I
>>>> was trying to install from the source code locally.
>>>> I've recently started using virtualenv, and for installation am
>>>> following the instructions from
>>>> https://pywps.readthedocs.io/en/latest/install.html
>>> they
>>> when I
>>> when
>>>> For the moment I have installed everything globally and it works
>>> but
>>>> is there a way to install everything in virtualenv? I tried
>>> installing
>>>> pywps in virtualenv (without sudo) but it gives some permission
>>> denied
>>>> error.
>>>> Also 'psutil' is not installed when you install from the
>>> requirements
>>>> files and before running demo.py I had to manually install it.
>>>> Thanks and regards,
>>>> Vikas Mishra
>>>> KK Birla Goa Campus
>>>> Sent with MailTrack [1]
>>>> Links:
>>>> [1]
>> https://mailtrack.io/install?source=signature&lang=en&referral=vikasmishra95@gmail.com&idSignature=22
>>>> _______________________________________________
>>>> pywps-dev mailing list
>>>> pywps-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev
