[Pywps-dev] Raster Output error
Lorenzo Bottaccioli
lorenzo.bottaccioli at gmail.com
Wed Jun 8 02:50:08 PDT 2016
Hi List,
I'm trying to run a process that recives a GeoTIFF as input and response a
GeoTIFF as output. But I'm having an error. The process is this:
from pywps import Process, ComplexInput, ComplexOutput,
get_format,LiteralOutput, Format
class Raster(Process):
def __init__(self):
inputs = [ComplexInput('raster','Raster input',[Format('GEOTIFF')])]
outputs = [ComplexOutput('raster_out', 'Raster
output',[Format('GEOJSON')]),LiteralOutput('response', 'Output response',
data_type='string')]
super(Raster, self).__init__(
self._handler,
identifier='rast_try',
title='Raster try',
inputs=inputs,
outputs=outputs,
store_supported=True,
status_supported=True
def _handler(self, request, response):
from osgeo import gdal
app=request.inputs['raster'][0].file
inds = gdal.Open(app)
outdriver = gdal.GetDriverByName('GTiff')
outds = outdriver.CreateCopy('output.tiff', inds)
outds.FlushCache()
response.outputs['raster_out'].output_format = Format('GEOTIFF')
response.outputs['raster_out'].file = 'output.tiff'
response.outputs['response'].file = 'done'
return response
The error that I recive is this one:
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
line 156, in _run_process
wps_response.update_status('PyWPS Process finished', 100)
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/WPSResponse.py",
line 41, in update_status
self.doc = self._construct_doc()
File
line 171, in _construct_doc
output_elements = [self.outputs[o].execute_xml() for o in self.outputs]
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/outputs.py",
line 276, in execute_xml
literal_data_doc = WPS.LiteralData(text_type(self.data))
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/basic.py",
line 231, in get_data
return IOHandler.get_data(self)
File
line 173, in get_data
file_handler = open(self.source, mode='r')
IOError: [Errno 2] No such file or directory:
'/tmp/pywps/pypws_process_lQqN_6/done'
ERROR:root:Service error: near "''": syntax error
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
line 358, in _parse_and_execute
wps_response = process.execute(wps_request, uuid)
File
line 145, in execute
wps_response = self._run_process(wps_request, wps_response)
File
line 178, in _run_process
wps_response.update_status('Process error: %s.%s Line %i %s' % (fname,
method_name, exc_tb.tb_lineno, e), -1)
File
line 47, in update_status
update_response(self.uuid, self)
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/dblog.py",
line 67, in update_response
cur.execute(update)
OperationalError: near "''": syntax error
How can I fix this?
Best,
Lorenzo
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160608/289ce5fd/attachment.html>
More information about the pywps-dev
