[Pywps-dev] Raster Output error
Jachym Cepicky
jachym.cepicky at gmail.com
Fri Jun 10 01:13:05 PDT 2016
Hi Lorenzo,
There are two bugs as I understand. The first one:
IOError: [Errno 2] No such file or directory:
'/tmp/pywps/pypws_process_lQqN_6/done'
do you have /tmp/pywps/ directory in you system (and is it writeable?)
The second bug is about attempt to write log to database
nice report btw, with the process I believe, we can fix it (both) once we
find out what the problem could be
Jachym
st 8. 6. 2016 v 11:50 odesÃlatel Lorenzo Bottaccioli <
lorenzo.bottaccioli at gmail.com> napsal:
> Hi List,
> I'm trying to run a process that recives a GeoTIFF as input and response a
> GeoTIFF as output. But I'm having an error. The process is this:
> from pywps import Process, ComplexInput, ComplexOutput,
> get_format,LiteralOutput, Format
> class Raster(Process):
> def __init__(self):
> inputs = [ComplexInput('raster','Raster
> input',[Format('GEOTIFF')])]
> outputs = [ComplexOutput('raster_out', 'Raster
> output',[Format('GEOJSON')]),LiteralOutput('response', 'Output response',
> data_type='string')]
> super(Raster, self).__init__(
> self._handler,
> identifier='rast_try',
> title='Raster try',
> inputs=inputs,
> outputs=outputs,
> store_supported=True,
> status_supported=True
> def _handler(self, request, response):
> from osgeo import gdal
> app=request.inputs['raster'][0].file
> inds = gdal.Open(app)
> outdriver = gdal.GetDriverByName('GTiff')
> outds = outdriver.CreateCopy('output.tiff', inds)
> outds.FlushCache()
> response.outputs['raster_out'].output_format = Format('GEOTIFF')
> response.outputs['raster_out'].file = 'output.tiff'
> response.outputs['response'].file = 'done'
> return response
> The error that I recive is this one:
> Traceback (most recent call last):
> File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
> line 156, in _run_process
> wps_response.update_status('PyWPS Process finished', 100)
> File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/WPSResponse.py",
> line 41, in update_status
> self.doc = self._construct_doc()
> File
> line 171, in _construct_doc
> output_elements = [self.outputs[o].execute_xml() for o in self.outputs]
> File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/outputs.py",
> line 276, in execute_xml
> literal_data_doc = WPS.LiteralData(text_type(self.data))
> File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/basic.py",
> line 231, in get_data
> return IOHandler.get_data(self)
> File
> line 173, in get_data
> file_handler = open(self.source, mode='r')
> ERROR:root:Service error: near "''": syntax error
> File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
> line 358, in _parse_and_execute
> wps_response = process.execute(wps_request, uuid)
> File
> line 145, in execute
> wps_response = self._run_process(wps_request, wps_response)
> File
> line 178, in _run_process
> wps_response.update_status('Process error: %s.%s Line %i %s' % (fname,
> method_name, exc_tb.tb_lineno, e), -1)
> File
> line 47, in update_status
> update_response(self.uuid, self)
> File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/dblog.py",
> line 67, in update_response
> cur.execute(update)
> OperationalError: near "''": syntax error
> How can I fix this?
> Best,
> Lorenzo
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160610/f8b9aeb1/attachment.html>
More information about the pywps-dev
