[Pywps-dev] Raster Output error
Lorenzo Bottaccioli lorenzo.bottaccioli at gmail.com
Tue Jun 28 01:28:42 PDT 2016
Hi Jachym,
I have changed my code in this. I create the file 'output.tiff' the error
indeed was not related to output.tiff.
from pywps import Process, ComplexInput, ComplexOutput,
get_format,LiteralOutput, Format
*class Raster(Process):*
*    def __init__(self):*
*        inputs = [ComplexInput('raster','Raster
input',[Format('GEOTIFF')])]*
*        outputs = [ComplexOutput('raster_out', 'Raster
output',[Format('GEOJSON')])]*
*        super(Raster, self).__init__(*
*            self._handler,*
*            identifier='rast_try',*
*            title='Raster try',*
*            inputs=inputs,*
*            outputs=outputs,*
*            store_supported=True,*
*            status_supported=True*
*    def _handler(self, request, response):*
*        from osgeo import gdal*
*        app=request.inputs['raster'][0].file*
*        inds = gdal.Open(app)*
*        outdriver = gdal.GetDriverByName('GTiff')*
*        outds = outdriver.CreateCopy('output.tiff', inds)*
*        outds.FlushCache()*
*        response.outputs['raster_out'].output_format = Format('GEOTIFF')*
*        response.outputs['raster_out'].file = 'output.tiff'*
*        return response*
 This is the Error:
130.192.5.114 - - [28/Jun/2016 10:26:51] "GET
/wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
HTTP/1.1" 500 -
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1836, in
__call__
    return self.wsgi_app(environ, start_response)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1820, in
wsgi_app
    response = self.make_response(self.handle_exception(e))
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1403, in
handle_exception
    reraise(exc_type, exc_value, tb)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1817, in
wsgi_app
    response = self.full_dispatch_request()
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1478, in
    response = self.make_response(rv)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1577, in
make_response
    rv = self.response_class.force_type(rv, request.environ)
  File
"/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/wrappers.py",
line 847, in force_type
    response = BaseResponse(*_run_wsgi_app(response, environ))
  File
line 57, in _run_wsgi_app
    return _run_wsgi_app(*args)
  File
"/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/test.py",
line 871, in run_wsgi_app
    app_rv = app(environ, start_response)
  File
line 291, in application
    return f(*args[:-2] + (request,))(*args[-2:])
  File
  File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/WPSResponse.py",
line 180, in __call__
    except HTTPException as httpexp:
NameError: global name 'HTTPException' is not defined
I'll test your banch ASAP and I let you know.
Tnx,
Lorenzo
2016-06-27 22:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> Lorenzo,
> two things,
> in your code:
> IOError: [Errno 2] No such file or directory:
> '/tmp/pywps/pypws_process_lQqN_6/done'
> ERROR:root:Service error: near "''": syntax error
> means - you can not save output.file as 'done' - it must be file name
> second: there was bug in pywps, which lead to error while constructing the
> final response from pywps, please test pygrass branch in my repository
> https://github.com/jachym/pywps/tree/pygrass
> one more time:
> should work ASSUMING, output.tiff is existing file!
> pá 24. 6. 2016 v 13:17 odesílatel Lorenzo Bottaccioli <
> lorenzo.bottaccioli at gmail.com> napsal:
>> Hi all,
>> Can you please show a simple PyWPS process that revice a geotiff and
>> returns it back and the url for requesting it?.
>> I'm not finding a way to do that.
>> Thanks in advantage,
>> Best
>> Lorenzo
>> 2016-06-21 17:40 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>> hi,
>>> if you are running pywps in apache2, it's usually
>>> /var/log/apache2/error.log
>>> if flask - it should be written to the command line
>>> look for some pythonish error
>>> po 20. 6. 2016 v 17:29 odesílatel Lorenzo Bottaccioli <
>>>> Hi Jachym,
>>>> As I wrote in the previous mail I have changed
>>>> response.outputs['response'].file* = 'done' *in
>>>> response.outputs['response'].data = 'done'  .
>>>> But I stil get an error:
>>>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
>>>> <title>500 Internal Server Error</title>
>>>> <h1>Internal Server Error</h1>
>>>> <p>The server encountered an internal error and was unable to complete
>>>> your request.  Either the server is overloaded or there is an error in the
>>>> application.</p>
>>>> Which is the HTTPD error.log file? The pywps.log file is always empty
>>>> and the log level is set to DEBUG
>>>> Best,
>>>> Lorenzo
>>>> 2016-06-18 23:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>>>> hi,
>>>>> as jonas was saying: response.outputs['response'].data = 'done'
>>>>> should work better
>>>>> Lorenzo:  do you get anything in the HTTPD server error.log file?
>>>>> pá 10. 6. 2016 v 15:30 odesílatel Lorenzo Bottaccioli <
>>>>>> Hi,
>>>>>> I'have changed from file to data in response.outputs['response'].data
>>>>>> = 'done', but bow I still get an error in the response.
>>>>>> complete your request.  Either the server is overloaded or there is an
>>>>>> error in the application.</p>
>>>>>> The GET request is written like this:
>>>>>> http://130.192.5.114:8080/wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
>>>>>> In the terminal I dont get any error report.
>>>>>> Tnx,
>>>>>> Lorenzo
>>>>>> 2016-06-10 10:20 GMT+02:00 Jonas Eberle <jonas.eberle at gmx.de>:
>>>>>>> The error "no such file or directory" comes from the following line:
>>>>>>> response.outputs['response'].file = 'done'
>>>>>>> As response is a LiteralOutput I guess it is not correct to use
>>>>>>> the file attribute, better use the data attribute:
>>>>>>> Cheers,
>>>>>>> Jonas
>>>>>>> ----- Am 10. Jun 2016 um 10:13 schrieb Jachym Cepicky <
>>>>>>> Hi Lorenzo,
>>>>>>> There are two bugs as I understand. The first one:
>>>>>>> do you have /tmp/pywps/ directory in you system (and is it
>>>>>>> writeable?)
>>>>>>> The second bug is about attempt to write log to database
>>>>>>> nice report btw, with the process I believe, we can fix it (both)
>>>>>>> once we find out what the problem could be
>>>>>>> Jachym
>>>>>>> st 8. 6. 2016 v 11:50 odesílatel Lorenzo Bottaccioli <
>>>>>>>> Hi List,
>>>>>>>> I'm trying to run a process that recives a GeoTIFF as input and
>>>>>>>> response a GeoTIFF as output. But I'm having an error. The process is this:
>>>>>>>>     def __init__(self):
>>>>>>>> output',[Format('GEOJSON')]),LiteralOutput('response', 'Output response',
>>>>>>>> data_type='string')]
>>>>>>>>             self._handler,
>>>>>>>>             title='Raster try',
>>>>>>>>             inputs=inputs,
>>>>>>>>             outputs=outputs,
>>>>>>>>         outds.FlushCache()
>>>>>>>> Format('GEOTIFF')
>>>>>>>>         return response
>>>>>>>> The error that I recive is this one:
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
>>>>>>>> line 156, in _run_process
>>>>>>>>     wps_response.update_status('PyWPS Process finished', 100)
>>>>>>>>   File
>>>>>>>> line 41, in update_status
>>>>>>>>     self.doc = self._construct_doc()
>>>>>>>>   File
>>>>>>>> line 171, in _construct_doc
>>>>>>>>     output_elements = [self.outputs[o].execute_xml() for o in
>>>>>>>> self.outputs]
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/outputs.py",
>>>>>>>> line 276, in execute_xml
>>>>>>>>     literal_data_doc = WPS.LiteralData(text_type(self.data))
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/basic.py",
>>>>>>>> line 231, in get_data
>>>>>>>>     return IOHandler.get_data(self)
>>>>>>>>   File
>>>>>>>> line 173, in get_data
>>>>>>>>     file_handler = open(self.source, mode='r')
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
>>>>>>>> line 358, in _parse_and_execute
>>>>>>>>     wps_response = process.execute(wps_request, uuid)
>>>>>>>>   File
>>>>>>>> line 145, in execute
>>>>>>>>     wps_response = self._run_process(wps_request, wps_response)
>>>>>>>>   File
>>>>>>>> line 178, in _run_process
>>>>>>>>     wps_response.update_status('Process error: %s.%s Line %i %s' %
>>>>>>>> (fname, method_name, exc_tb.tb_lineno, e), -1)
>>>>>>>>   File
>>>>>>>> line 47, in update_status
>>>>>>>>     update_response(self.uuid, self)
>>>>>>>>   File
>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/dblog.py",
>>>>>>>> line 67, in update_response
>>>>>>>>     cur.execute(update)
>>>>>>>> OperationalError: near "''": syntax error
>>>>>>>> How can I fix this?
>>>>>>>> Best,
>>>>>>>> Lorenzo
>>>>>>>> _______________________________________________
>>>>>>>> pywps-dev mailing list
>>>>>>>> pywps-dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160628/fc0c3af4/attachment-0001.html>
More information about the pywps-dev mailing list
