[Pywps-dev] Raster Output error
Lorenzo Bottaccioli lorenzo.bottaccioli at gmail.com
Tue Jun 28 06:29:14 PDT 2016
HI all,
I have setup the pywps linked by Jachym (
https://github.com/jachym/pywps/tree/pygrass) run on Apache2 with mod_wsgi.
I have created a wsgi file with this script
*import sys*
*sys.path.insert(0, '/home/lorenzo/tools/pywps-4/')*
*import pywps*
*from pywps.app import Service,  Process*
*from processes.raster import Raster*
*from processes.solar.PV_NOCT import PV_CALC*
*from processes.get_year_rad import get_year_rad_pitch*
*from processes.get_year_rad_zstat import get_year_rad_pitch_query*
*from processes.get_year_rad_all import get_year_rad_all*
*from processes.solar.real_sky import Real_sky*
*application = Service(processes=[Raster(),*
* PV_CALC(),*
* get_year_rad_pitch(),*
* get_year_rad_pitch_query(),*
* Real_sky(),*
* get_year_rad_all()], cfgfile='/var/www/pywps/pywps.cfg')*
I still get an error when I try to use the Raster process which is:
*from pywps import Process, ComplexInput, ComplexOutput,
get_format,LiteralOutput, Format*
*class Raster(Process):*
*    def __init__(self):*
*        inputs = [ComplexInput('raster','Raster
input',[Format('GEOTIFF')])]*
*        outputs = [ComplexOutput('raster_out', 'Raster
output',[Format('GEOTIFF')]),LiteralOutput('response', 'Output response',
data_type='string')]*
*        super(Raster, self).__init__(*
*            self._handler,*
*            identifier='rast_try',*
*            title='Raster try',*
*            inputs=inputs,*
*            outputs=outputs,*
*            store_supported=True,*
*            status_supported=True*
*    def _handler(self, request, response):*
*        from osgeo import gdal*
*        app=request.inputs['raster'][0].file*
*        inds = gdal.Open(app)*
*        outdriver = gdal.GetDriverByName('GTiff')*
*        outds = outdriver.CreateCopy('output.tiff', inds)*
*        outds.FlushCache()*
*        response.outputs['raster_out'].output_format = Format('GEOTIFF')*
*        response.outputs['raster_out'].file = 'output.tiff'*
*        response.outputs['response'].data = 'done'*
*        return response*
 The error I get in the apache error.log is:
[Tue Jun 28 15:23:54.052594 2016] [:error] [pid 4437:tid 140256591759104]
ERROR:PYWPS:Exception: code: 400, locator: None, description:
[Tue Jun 28 15:23:54.052615 2016] [:error] [pid 4437:tid 140256591759104]
[Tue Jun 28 15:23:54.052617 2016] [:error] [pid 4437:tid 140256591759104]
File
"/usr/local/lib/python2.7/dist-packages/pywps-4.0.0_alpha2-py2.7.egg/pywps/app/WPSRequest.py",
line 80, in _post_request
[Tue Jun 28 15:23:54.052618 2016] [:error] [pid 4437:tid 140256591759104]
  doc = lxml.etree.fromstring(self.http_request.get_data())
[Tue Jun 28 15:23:54.052620 2016] [:error] [pid 4437:tid 140256591759104]
File "lxml.etree.pyx", line 3032, in lxml.etree.fromstring
(src/lxml/lxml.etree.c:68106)
[Tue Jun 28 15:23:54.052622 2016] [:error] [pid 4437:tid 140256591759104]
File "parser.pxi", line 1785, in lxml.etree._parseMemoryDocument
(src/lxml/lxml.etree.c:102455)
[Tue Jun 28 15:23:54.052626 2016] [:error] [pid 4437:tid 140256591759104]
File "parser.pxi", line 1673, in lxml.etree._parseDoc
(src/lxml/lxml.etree.c:101284)
[Tue Jun 28 15:23:54.052628 2016] [:error] [pid 4437:tid 140256591759104]
File "parser.pxi", line 1074, in lxml.etree._BaseParser._parseDoc
(src/lxml/lxml.etree.c:96466)
[Tue Jun 28 15:23:54.052629 2016] [:error] [pid 4437:tid 140256591759104]
File "parser.pxi", line 582, in
lxml.etree._ParserContext._handleParseResultDoc
(src/lxml/lxml.etree.c:91275)
[Tue Jun 28 15:23:54.052630 2016] [:error] [pid 4437:tid 140256591759104]
File "parser.pxi", line 683, in lxml.etree._handleParseResult
(src/lxml/lxml.etree.c:92461)
[Tue Jun 28 15:23:54.052632 2016] [:error] [pid 4437:tid 140256591759104]
File "parser.pxi", line 633, in lxml.etree._raiseParseError
(src/lxml/lxml.etree.c:91924)
[Tue Jun 28 15:23:54.052633 2016] [:error] [pid 4437:tid 140256591759104]
XMLSyntaxError: None
Any suggestion to solve it?
Best,
Lorenzo
2016-06-28 10:28 GMT+02:00 Lorenzo Bottaccioli <
lorenzo.bottaccioli at gmail.com>:
> Hi Jachym,
> I have changed my code in this. I create the file 'output.tiff' the error
> indeed was not related to output.tiff.
> output',[Format('GEOJSON')])]*
> *            self._handler,*
> *            inputs=inputs,*
> *            outputs=outputs,*
> *        return response*
>  This is the Error:
> 130.192.5.114 - - [28/Jun/2016 10:26:51] "GET
> /wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
> HTTP/1.1" 500 -
>   File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1836,
> in __call__
>     return self.wsgi_app(environ, start_response)
>   File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1820,
> in wsgi_app
>     response = self.make_response(self.handle_exception(e))
>   File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1403,
> in handle_exception
>     reraise(exc_type, exc_value, tb)
>   File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1817,
> in wsgi_app
>     response = self.full_dispatch_request()
>   File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1478,
> in full_dispatch_request
>     response = self.make_response(rv)
>   File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1577,
> in make_response
>     rv = self.response_class.force_type(rv, request.environ)
>   File
> "/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/wrappers.py",
> line 847, in force_type
>     response = BaseResponse(*_run_wsgi_app(response, environ))
>   File
> line 57, in _run_wsgi_app
>     return _run_wsgi_app(*args)
>   File
> "/usr/local/lib/python2.7/dist-packages/Werkzeug-0.11.4-py2.7.egg/werkzeug/test.py",
> line 871, in run_wsgi_app
>     app_rv = app(environ, start_response)
>   File
> line 291, in application
>     return f(*args[:-2] + (request,))(*args[-2:])
>   File
>   File
> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/WPSResponse.py",
> line 180, in __call__
>     except HTTPException as httpexp:
> NameError: global name 'HTTPException' is not defined
> I'll test your banch ASAP and I let you know.
> Tnx,
> Lorenzo
> 2016-06-27 22:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>> Lorenzo,
>> two things,
>> in your code:
>> IOError: [Errno 2] No such file or directory:
>> '/tmp/pywps/pypws_process_lQqN_6/done'
>> ERROR:root:Service error: near "''": syntax error
>> means - you can not save output.file as 'done' - it must be file name
>> second: there was bug in pywps, which lead to error while constructing
>> the final response from pywps, please test pygrass branch in my repository
>> one more time:
>> should work ASSUMING, output.tiff is existing file!
>> pá 24. 6. 2016 v 13:17 odesílatel Lorenzo Bottaccioli <
>> lorenzo.bottaccioli at gmail.com> napsal:
>>> Hi all,
>>> Can you please show a simple PyWPS process that revice a geotiff and
>>> returns it back and the url for requesting it?.
>>> I'm not finding a way to do that.
>>> Thanks in advantage,
>>> Best
>>> Lorenzo
>>> 2016-06-21 17:40 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>>> hi,
>>>> if you are running pywps in apache2, it's usually
>>>> /var/log/apache2/error.log
>>>> if flask - it should be written to the command line
>>>> look for some pythonish error
>>>> po 20. 6. 2016 v 17:29 odesílatel Lorenzo Bottaccioli <
>>>>> Hi Jachym,
>>>>> As I wrote in the previous mail I have changed
>>>>> response.outputs['response'].file* = 'done' *in
>>>>> response.outputs['response'].data = 'done'  .
>>>>> But I stil get an error:
>>>>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2 Final//EN">
>>>>> <title>500 Internal Server Error</title>
>>>>> <h1>Internal Server Error</h1>
>>>>> <p>The server encountered an internal error and was unable to complete
>>>>> your request.  Either the server is overloaded or there is an error in the
>>>>> application.</p>
>>>>> Which is the HTTPD error.log file? The pywps.log file is always empty
>>>>> and the log level is set to DEBUG
>>>>> Best,
>>>>> Lorenzo
>>>>> 2016-06-18 23:39 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>>>>> hi,
>>>>>> as jonas was saying: response.outputs['response'].data = 'done'
>>>>>> should work better
>>>>>> Lorenzo:  do you get anything in the HTTPD server error.log file?
>>>>>> pá 10. 6. 2016 v 15:30 odesílatel Lorenzo Bottaccioli <
>>>>>>> Hi,
>>>>>>> I'have changed from file to data in response.outputs['response'].data
>>>>>>> = 'done', but bow I still get an error in the response.
>>>>>>> complete your request.  Either the server is overloaded or there is an
>>>>>>> error in the application.</p>
>>>>>>> The GET request is written like this:
>>>>>>> http://130.192.5.114:8080/wps?service=wps&version=1.0.0&request=execute&Identifier=rast_try&datainputs=raster=@xlink:href=file:///home/lorenzo/aspect_1ifGBx0
>>>>>>> In the terminal I dont get any error report.
>>>>>>> Tnx,
>>>>>>> Lorenzo
>>>>>>> 2016-06-10 10:20 GMT+02:00 Jonas Eberle <jonas.eberle at gmx.de>:
>>>>>>>> The error "no such file or directory" comes from the following
>>>>>>>> line:
>>>>>>>> response.outputs['response'].file = 'done'
>>>>>>>> As response is a LiteralOutput I guess it is not correct to use
>>>>>>>> the file attribute, better use the data attribute:
>>>>>>>> Cheers,
>>>>>>>> Jonas
>>>>>>>> ----- Am 10. Jun 2016 um 10:13 schrieb Jachym Cepicky <
>>>>>>>> Hi Lorenzo,
>>>>>>>> There are two bugs as I understand. The first one:
>>>>>>>> do you have /tmp/pywps/ directory in you system (and is it
>>>>>>>> writeable?)
>>>>>>>> The second bug is about attempt to write log to database
>>>>>>>> nice report btw, with the process I believe, we can fix it (both)
>>>>>>>> once we find out what the problem could be
>>>>>>>> Jachym
>>>>>>>> st 8. 6. 2016 v 11:50 odesílatel Lorenzo Bottaccioli <
>>>>>>>>> Hi List,
>>>>>>>>> I'm trying to run a process that recives a GeoTIFF as input and
>>>>>>>>> response a GeoTIFF as output. But I'm having an error. The process is this:
>>>>>>>>>     def __init__(self):
>>>>>>>>> output',[Format('GEOJSON')]),LiteralOutput('response', 'Output response',
>>>>>>>>>             self._handler,
>>>>>>>>>             title='Raster try',
>>>>>>>>>             inputs=inputs,
>>>>>>>>>             outputs=outputs,
>>>>>>>>>         outds.FlushCache()
>>>>>>>>> Format('GEOTIFF')
>>>>>>>>>         return response
>>>>>>>>> The error that I recive is this one:
>>>>>>>>>   File
>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Process.py",
>>>>>>>>> line 156, in _run_process
>>>>>>>>>     wps_response.update_status('PyWPS Process finished', 100)
>>>>>>>>>   File
>>>>>>>>> line 41, in update_status
>>>>>>>>>     self.doc = self._construct_doc()
>>>>>>>>>   File
>>>>>>>>> line 171, in _construct_doc
>>>>>>>>>     output_elements = [self.outputs[o].execute_xml() for o in
>>>>>>>>> self.outputs]
>>>>>>>>>   File
>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/outputs.py",
>>>>>>>>> line 276, in execute_xml
>>>>>>>>>     literal_data_doc = WPS.LiteralData(text_type(self.data))
>>>>>>>>>   File
>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/inout/basic.py",
>>>>>>>>> line 231, in get_data
>>>>>>>>>     return IOHandler.get_data(self)
>>>>>>>>>   File
>>>>>>>>> line 173, in get_data
>>>>>>>>>     file_handler = open(self.source, mode='r')
>>>>>>>>>   File
>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/app/Service.py",
>>>>>>>>> line 358, in _parse_and_execute
>>>>>>>>>     wps_response = process.execute(wps_request, uuid)
>>>>>>>>>   File
>>>>>>>>> line 145, in execute
>>>>>>>>>     wps_response = self._run_process(wps_request, wps_response)
>>>>>>>>>   File
>>>>>>>>> line 178, in _run_process
>>>>>>>>>     wps_response.update_status('Process error: %s.%s Line %i %s' %
>>>>>>>>> (fname, method_name, exc_tb.tb_lineno, e), -1)
>>>>>>>>>   File
>>>>>>>>> line 47, in update_status
>>>>>>>>>     update_response(self.uuid, self)
>>>>>>>>>   File
>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/pywps-4.0-py2.7.egg/pywps/dblog.py",
>>>>>>>>> line 67, in update_response
>>>>>>>>>     cur.execute(update)
>>>>>>>>> OperationalError: near "''": syntax error
>>>>>>>>> How can I fix this?
>>>>>>>>> Best,
>>>>>>>>> Lorenzo
>>>>>>>>> _______________________________________________
>>>>>>>>> pywps-dev mailing list
>>>>>>>>> pywps-dev at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160628/b8891b41/attachment-0001.html>
More information about the pywps-dev mailing list
