[Pywps-dev] pip install pywps
Jachym Cepicky jachym.cepicky at gmail.com
Wed Jun 29 11:40:59 PDT 2016
I have the kyes, but not sure, what I do - I had feeling, we published the
most up-to-date version to pypi? Any hint what I should do?
J
st 29. 6. 2016 v 19:46 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> I'm able to reproduce.
> Looks like the egg publishing is problematic for some reason.
> Running the following always works (for other projects):
> python setup.py sdist upload
> This uploads a tar.gz which will work.
> Perhaps we can cut 3.2.6 as I think PyPI has certain
> rules on overriding versions.  I think Jachym has the keys
> to PyWPS' PyPI entry, but I can help if given access prives.
> Thanks
> ..Tom
> On Wed, 29 Jun 2016, Jonas Eberle wrote:
> > Date: Wed, 29 Jun 2016 12:06:24 -0500 (CDT)
> > From: Jonas Eberle <jonas.eberle at gmx.de>
> > To: pywps-dev at lists.osgeo.org
> > Subject: [Pywps-dev] pip install pywps
> > Dear all,
> > I downladed the current OSGeo-Live 9.5 and tried to install pywps 3. But
> using sudo pip install pywps (Python 2.7), I get the following error:
> > "Could not find a version that satisfies the requirement pywps"
> > I can install other packages from PyPi without problems.
> > Any ideas?
> > Thanks,
> > Jonas
> pywps-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160629/b2b1f93a/attachment.html>
More information about the pywps-dev mailing list
