[Pywps-dev] pip install pywps
Tom Kralidis tomkralidis at gmail.com
Thu Jun 30 04:15:39 PDT 2016
Jachym: I cut 3.2.6 release just now. Can you publish to PyPI adding the sdist to the upload?
Sent from my iPhone
> On Jun 29, 2016, at 14:40, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> I have the kyes, but not sure, what I do - I had feeling, we published the most up-to-date version to pypi? Any hint what I should do?
> J
> st 29. 6. 2016 v 19:46 odesílatel Tom Kralidis <tomkralidis at gmail.com> napsal:
>> I'm able to reproduce.
>> Looks like the egg publishing is problematic for some reason.
>> Running the following always works (for other projects):
>> python setup.py sdist upload
>> This uploads a tar.gz which will work.
>> Perhaps we can cut 3.2.6 as I think PyPI has certain
>> rules on overriding versions.  I think Jachym has the keys
>> to PyWPS' PyPI entry, but I can help if given access prives.
>> Thanks
>> ..Tom
>> On Wed, 29 Jun 2016, Jonas Eberle wrote:
>> > Date: Wed, 29 Jun 2016 12:06:24 -0500 (CDT)
>> > From: Jonas Eberle <jonas.eberle at gmx.de>
>> > To: pywps-dev at lists.osgeo.org
>> > Subject: [Pywps-dev] pip install pywps
>> > Dear all,
>> > I downladed the current OSGeo-Live 9.5 and tried to install pywps 3. But using sudo pip install pywps (Python 2.7), I get the following error:
>> > "Could not find a version that satisfies the requirement pywps"
>> > I can install other packages from PyPi without problems.
>> > Any ideas?
>> > Thanks,
>> > Jonas
>> pywps-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160630/cd4a47ca/attachment.html>
More information about the pywps-dev mailing list
