[PyWPS-dev] Process Chaining
Carsten Ehbrecht ehbrecht at dkrz.de
Thu Dec 6 05:54:12 PST 2018
Hi Suzana,
I haven’t tried process chaining for a long time and I didn’t investigate. But it would be nice to find out :)
There can be issues both in owslib.wps and pywps. I would recommend to start with “pure” WPS requests and not using owslib.wps (which might not support chaining at the moment).
Some links on testing pywps:
* https://github.com/PyWPS/pywps-workshop/blob/master/03-Testing.md <https://github.com/PyWPS/pywps-workshop/blob/master/03-Testing.md>
* https://birdhouse-workshop.readthedocs.io/en/latest/pywps/testing.html <https://birdhouse-workshop.readthedocs.io/en/latest/pywps/testing.html>
I can share my links on WPS chaining:
* https://geoserver.geo-solutions.it/edu/en/wps/chaining_processes.html <https://geoserver.geo-solutions.it/edu/en/wps/chaining_processes.html>
And also something with PyWPS but with the old 3.x version … don’t use it, just for reference:
* https://github.com/AnnaHomolka/PyWPS/blob/master/doc/tutorial_process_chaining.pdf <https://github.com/AnnaHomolka/PyWPS/blob/master/doc/tutorial_process_chaining.pdf>
* https://www.slideshare.net/foss4g2011/eberle-processing-chainsmodispresentation <https://www.slideshare.net/foss4g2011/eberle-processing-chainsmodispresentation>
Please share you experience … you may use a GitHub issue.
Sorry, for the wait.
Cheers,
Carsten
Carsten Ehbrecht
Abteilung Datenmanagement
Deutsches Klimarechenzentrum GmbH (DKRZ)
Bundesstraße 45 a • D-20146 Hamburg • Germany
Phone: +49 40 460094-148
FAX:   +49 40 460094-270
Email: ehbrecht at dkrz.de
URL:   www.dkrz.de
Geschäftsführer: Prof. Dr. Thomas Ludwig
Sitz der Gesellschaft: Hamburg
Amtsgericht Hamburg HRB 39784
> On 12 Nov 2018, at 3:53 pm, Suzana Barreto <suzana.barreto at envsys.co.uk> wrote:
> Hi All,
> I was wondering if there is an xml template or xml example of a chained process POST request.  I have been trying to use OWSLib to chain my PyWPS Process requests but am finding it difficult as there is no examples of how this is achieved using OWSLib.  I have been able to 'simulate' a chained request by sending requests in order and then using the output from the first as the input to the next.  I have also tried embedding a request in another but have found that the library escapes the xml special characters, resulting in malformed xml.  I also attempted to manually create an XML POST request but not sure how the embedding is achieved ie. what is the element called that identifies a chained or embedded request.  So I would therefore like to know if anyone can point me in the right direction in terms of what the XML for a chained PyWPS request would look like.
> Thanks,
> Suzana
> Dr Suzana Barreto
> Software Analyst
> Environment Systems
> Tel: +44 (0) 1970 626688 <tel:%2B44%20%280%29%201970%20626688>
> www.envsys.co.uk <http://www.envsys.co.uk/>
> The information contained in this e-mail is intended only for the use of the person(s) to whom it is addressed and may contain confidential or privileged information. If you have received this e-mail in error please contact the sender and delete the material without copying, distributing or disclosing the content. All reasonable precautions have been taken to ensure that this e-mail is free from any virus, however, the recipient should verify this to be the case. Please 'think before you print'
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181206/45e24b0a/attachment.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181206/45e24b0a/attachment.bin>
More information about the pywps-dev mailing list
