[PyWPS-dev] Process Chaining
Suzana Barreto
suzana.barreto at envsys.co.uk
Wed Dec 12 01:42:12 PST 2018
Hi Carsten,
Thanks for getting back to me with the info, the links on testing are
definitely helpful, and I had come across the Ana Homolka contribution but
I was not sure whether it had been implemented in the current version of
PyWPS. I think it should be possible to chain processes using the XML
approach given the correct tag to nest within the input section of a
process, the next execute request. Unfortunately, the geoserver chained
xml docs are not compatible.
Thanks again,
Suzana
On Thu, 6 Dec 2018 at 13:54, Carsten Ehbrecht <ehbrecht at dkrz.de> wrote:
> Hi Suzana,
> I haven’t tried process chaining for a long time and I didn’t investigate.
> But it would be nice to find out :)
> There can be issues both in owslib.wps and pywps. I would recommend to
> start with “pure” WPS requests and not using owslib.wps (which might not
> support chaining at the moment).
> Some links on testing pywps:
> * https://github.com/PyWPS/pywps-workshop/blob/master/03-Testing.md
> * https://birdhouse-workshop.readthedocs.io/en/latest/pywps/testing.html
> I can share my links on WPS chaining:
> * https://geoserver.geo-solutions.it/edu/en/wps/chaining_processes.html
> And also something with PyWPS but with the old 3.x version … don’t use it,
> just for reference:
> https://github.com/AnnaHomolka/PyWPS/blob/master/doc/tutorial_process_chaining.pdf
> https://www.slideshare.net/foss4g2011/eberle-processing-chainsmodispresentation
> Please share you experience … you may use a GitHub issue.
> Sorry, for the wait.
> Cheers,
> Carsten
> Carsten Ehbrecht
> Abteilung Datenmanagement
> Deutsches Klimarechenzentrum GmbH (DKRZ)
> Bundesstraße 45 a • D-20146 Hamburg • Germany
> Phone: +49 40 460094-148
> FAX: +49 40 460094-270
> Email: ehbrecht at dkrz.de <ehbrecht at dkrz.de>
> URL: www.dkrz.de
> Geschäftsführer: Prof. Dr. Thomas Ludwig
> Sitz der Gesellschaft: Hamburg
> Amtsgericht Hamburg HRB 39784
> On 12 Nov 2018, at 3:53 pm, Suzana Barreto <suzana.barreto at envsys.co.uk>
> wrote:
> Hi All,
> I was wondering if there is an xml template or xml example of a chained
> process POST request. I have been trying to use OWSLib to chain my PyWPS
> Process requests but am finding it difficult as there is no examples of how
> this is achieved using OWSLib. I have been able to 'simulate' a chained
> request by sending requests in order and then using the output from the
> first as the input to the next. I have also tried embedding a request in
> another but have found that the library escapes the xml special characters,
> resulting in malformed xml. I also attempted to manually create an XML
> POST request but not sure how the embedding is achieved ie. what is the
> element called that identifies a chained or embedded request. So I would
> therefore like to know if anyone can point me in the right direction in
> terms of what the XML for a chained PyWPS request would look like.
> Thanks,
> Suzana
> *Dr Suzana BarretoSoftware AnalystEnvironment Systems*
> Tel: +44 (0) 1970 626688
> www.envsys.co.uk
> The information contained in this e-mail is intended only for the use of
> the person(s) to whom it is addressed and may contain confidential or
> privileged information. If you have received this e-mail in error please
> contact the sender and delete the material without copying, distributing or
> disclosing the content. All reasonable precautions have been taken to
> ensure that this e-mail is free from any virus, however, the recipient
> should verify this to be the case. Please 'think before you print'
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pywps-dev
www.envsys.co.uk
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181212/b7efd987/attachment-0001.html>
More information about the pywps-dev
