[PyWPS-dev] Running a subprocess via pyWPS?
Carsten Ehbrecht
ehbrecht at dkrz.de
Fri Dec 7 06:29:37 PST 2018
Hi Derek,
I just had a glimpse view on your code example. If I understand it correctly your PyWPS process is calling a threaded python function. So, I would try to test both independently … the process (just returning a dummy result) and your python function.
To test pywps you might find hints here:
* https://github.com/PyWPS/pywps-workshop/blob/master/03-Testing.md <https://github.com/PyWPS/pywps-workshop/blob/master/03-Testing.md>
* https://birdhouse-workshop.readthedocs.io/en/latest/pywps/testing.html <https://birdhouse-workshop.readthedocs.io/en/latest/pywps/testing.html>
* https://github.com/bird-house/emu/blob/master/tests/test_wps_hello.py <https://github.com/bird-house/emu/blob/master/tests/test_wps_hello.py>
Cheers,
Carsten
> On 7 Dec 2018, at 1:40 pm, Derek Hohls <dhohls at csir.co.za> wrote:
> Hi
> I am using pyWPS 4. I am trying to use it to trigger the opening of a sub-process in a thread. However, I get no response back, nor does the subprocess appear to activate.
> I am looking for help in (a) how to get this going and (b) how to debug what the cause of the issue is.
> I have a attached a sample 'dummy' app (Note that for my actual application, the thread that is launched is expected to run continuously in the background; so the "ls" function I have used here is not a really good, representative example but the simplest one I could think of).
> Thanks in advance
> Derek
> <thread_runner.py><thread_controller.py>_______________________________________________
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org <mailto:pywps-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/pywps-dev <https://lists.osgeo.org/mailman/listinfo/pywps-dev>
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181207/f02e712f/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181207/f02e712f/attachment-0001.bin>
More information about the pywps-dev
