[PyWPS-dev] master or develop
David Huard
huard.david at ouranos.ca
Tue Dec 11 05:32:10 PST 2018
Hi Adam,
I think we have the same issue :
https://github.com/geopython/pywps/issues/412
My guess is that it's either due to my refactoring or to the new templates
or a combination of both.
I noticed that if you do
ComplexOutput.data = <file content>
... then it works
but if you do
ComplexOutput.file = <file path>
it doesn't. Hopefully this is a hint as to what is going wrong.
I think the offending bit is is inout.outputs.ComplexOutput. If the
ComplexOutput is a file and as_reference is False, _json_data is called
which I think might fail to fill the json data field. It's not obvious why
though. Do you have a test case you could add to the test suite ?
HTH,
David
On Tue, Dec 11, 2018 at 4:06 AM Adam Laža <ad.laza32 at gmail.com> wrote:
> Hi Carsten,
> thanks for reply. Good to know. However since I switched for master branch
> I can get output in ExecuteResponse only as reference. Even if I force
> attribute asReference=false I still get only reference to output, not the
> output directly.
> I use pywps-flask demo server and Buffer process for testing. Any idea
> what could be wrong?
> Cheers,
> Adam
> út 11. 12. 2018 v 0:16 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
> napsal:
>> Hi Adam,
>> yes, please use master branch to rebase. We switched awhile ago (Code
>> sprint Bonn in March?).
>> Cheers,
>> Carsten
>> > On 8 Dec 2018, at 04:16, Adam Laža <ad.laza32 at gmail.com> wrote:
>> > Hi devs,
>> > I'd like to make a new PR for my Docker extension in few days. Now I'm
>> just bit confused because I wanted to rebase my branch onto develop branch
>> to avoid conflicts but it seems to me that develop branch is no more used
>> and that you use master instead (develop has last commit July 16, master 26
>> days ago).
>> > Could anyone confirm that right approach is to rebase onto master and
>> make a PR against master?
>> > Thanks,
>> > Adam
>> > _______________________________________________
>> > pywps-dev mailing list
>> > pywps-dev at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181211/0363e8de/attachment.html>
More information about the pywps-dev
