[PyWPS-dev] master or develop
David Huard
huard.david at ouranos.ca
Wed Dec 12 11:00:22 PST 2018
Hi Adam, I've created a PR for your bug fix. Does it work for you ? It
seems to work on my use cases.
On Wed, Dec 12, 2018 at 9:31 AM David Huard <huard.david at ouranos.ca> wrote:
> Looks good, trying to write a few tests to exercise it.
> Good catch !
> On Wed, Dec 12, 2018 at 1:02 AM Adam Laža <ad.laza32 at gmail.com> wrote:
>> Hi David,
>> check my bug fix [1]. It works for me but I would like to know if it is
>> right approach.
>> Cheers,
>> Adam
>> [1]:
>> https://github.com/lazaa32/pywps/commit/5cccc38c997965d4566b21df0badf3244021bdeb
>> st 12. 12. 2018 v 2:32 odesílatel David Huard <huard.david at ouranos.ca>
>> napsal:
>>> Hi Adam,
>>> I think we have the same issue :
>>> https://github.com/geopython/pywps/issues/412
>>> My guess is that it's either due to my refactoring or to the new
>>> templates or a combination of both.
>>> I noticed that if you do
>>> ComplexOutput.data = <file content>
>>> ... then it works
>>> but if you do
>>> ComplexOutput.file = <file path>
>>> it doesn't. Hopefully this is a hint as to what is going wrong.
>>> I think the offending bit is is inout.outputs.ComplexOutput. If the
>>> ComplexOutput is a file and as_reference is False, _json_data is called
>>> which I think might fail to fill the json data field. It's not obvious why
>>> though. Do you have a test case you could add to the test suite ?
>>> HTH,
>>> David
>>> On Tue, Dec 11, 2018 at 4:06 AM Adam Laža <ad.laza32 at gmail.com> wrote:
>>>> Hi Carsten,
>>>> thanks for reply. Good to know. However since I switched for master
>>>> branch I can get output in ExecuteResponse only as reference. Even if I
>>>> force attribute asReference=false I still get only reference to output, not
>>>> the output directly.
>>>> I use pywps-flask demo server and Buffer process for testing. Any idea
>>>> what could be wrong?
>>>> Cheers,
>>>> Adam
>>>> út 11. 12. 2018 v 0:16 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
>>>> napsal:
>>>>> Hi Adam,
>>>>> yes, please use master branch to rebase. We switched awhile ago (Code
>>>>> sprint Bonn in March?).
>>>>> Cheers,
>>>>> Carsten
>>>>> > On 8 Dec 2018, at 04:16, Adam Laža <ad.laza32 at gmail.com> wrote:
>>>>> > Hi devs,
>>>>> > I'd like to make a new PR for my Docker extension in few days. Now
>>>>> I'm just bit confused because I wanted to rebase my branch onto develop
>>>>> branch to avoid conflicts but it seems to me that develop branch is no more
>>>>> used and that you use master instead (develop has last commit July 16,
>>>>> master 26 days ago).
>>>>> > Could anyone confirm that right approach is to rebase onto master
>>>>> and make a PR against master?
>>>>> > Thanks,
>>>>> > Adam
>>>>> > _______________________________________________
>>>>> > pywps-dev mailing list
>>>>> > pywps-dev at lists.osgeo.org
>>>>> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181212/b7707916/attachment.html>
More information about the pywps-dev
