[PyWPS-dev] master or develop
David Huard
huard.david at ouranos.ca
Wed Dec 12 06:31:36 PST 2018
Looks good, trying to write a few tests to exercise it.
Good catch !
On Wed, Dec 12, 2018 at 1:02 AM Adam Laža <ad.laza32 at gmail.com> wrote:
> Hi David,
> check my bug fix [1]. It works for me but I would like to know if it is
> right approach.
> Cheers,
> Adam
> [1]:
> https://github.com/lazaa32/pywps/commit/5cccc38c997965d4566b21df0badf3244021bdeb
> st 12. 12. 2018 v 2:32 odesílatel David Huard <huard.david at ouranos.ca>
> napsal:
>> Hi Adam,
>> I think we have the same issue :
>> https://github.com/geopython/pywps/issues/412
>> My guess is that it's either due to my refactoring or to the new
>> templates or a combination of both.
>> I noticed that if you do
>> ComplexOutput.data = <file content>
>> ... then it works
>> but if you do
>> ComplexOutput.file = <file path>
>> it doesn't. Hopefully this is a hint as to what is going wrong.
>> I think the offending bit is is inout.outputs.ComplexOutput. If the
>> ComplexOutput is a file and as_reference is False, _json_data is called
>> which I think might fail to fill the json data field. It's not obvious why
>> though. Do you have a test case you could add to the test suite ?
>> HTH,
>> David
>> On Tue, Dec 11, 2018 at 4:06 AM Adam Laža <ad.laza32 at gmail.com> wrote:
>>> Hi Carsten,
>>> thanks for reply. Good to know. However since I switched for master
>>> branch I can get output in ExecuteResponse only as reference. Even if I
>>> force attribute asReference=false I still get only reference to output, not
>>> the output directly.
>>> I use pywps-flask demo server and Buffer process for testing. Any idea
>>> what could be wrong?
>>> Cheers,
>>> Adam
>>> út 11. 12. 2018 v 0:16 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
>>> napsal:
>>>> Hi Adam,
>>>> yes, please use master branch to rebase. We switched awhile ago (Code
>>>> sprint Bonn in March?).
>>>> Cheers,
>>>> Carsten
>>>> > On 8 Dec 2018, at 04:16, Adam Laža <ad.laza32 at gmail.com> wrote:
>>>> > Hi devs,
>>>> > I'd like to make a new PR for my Docker extension in few days. Now
>>>> I'm just bit confused because I wanted to rebase my branch onto develop
>>>> branch to avoid conflicts but it seems to me that develop branch is no more
>>>> used and that you use master instead (develop has last commit July 16,
>>>> master 26 days ago).
>>>> > Could anyone confirm that right approach is to rebase onto master and
>>>> make a PR against master?
>>>> > Thanks,
>>>> > Adam
>>>> > _______________________________________________
>>>> > pywps-dev mailing list
>>>> > pywps-dev at lists.osgeo.org
>>>> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181212/42312e9a/attachment.html>
More information about the pywps-dev
