[PyWPS-dev] master or develop
Carsten Ehbrecht
ehbrecht at dkrz.de
Fri Dec 14 00:29:45 PST 2018
Hi Adam,
If you have an improved version of the bugfix could please open a PR?
Here is the one from David:
https://github.com/geopython/pywps/pull/431
Cheers,
Carsten
> On 14 Dec 2018, at 09:10, Adam Laža <ad.laza32 at gmail.com> wrote:
> Hi David,
> Just cosmetics, I slightly edited the template. CDATA tag is not present if we know that mimeType is XML-based. Response XML looks better then.
> A.
> [1]: https://github.com/lazaa32/pywps/commit/f8b66e3f43f027ec3f20eacf9a82f9ac9c0e8499
> čt 13. 12. 2018 v 8:00 odesílatel David Huard <huard.david at ouranos.ca> napsal:
> Hi Adam, I've created a PR for your bug fix. Does it work for you ? It seems to work on my use cases.
> On Wed, Dec 12, 2018 at 9:31 AM David Huard <huard.david at ouranos.ca> wrote:
> Looks good, trying to write a few tests to exercise it.
> Good catch !
> On Wed, Dec 12, 2018 at 1:02 AM Adam Laža <ad.laza32 at gmail.com> wrote:
> Hi David,
> check my bug fix [1]. It works for me but I would like to know if it is right approach.
> Cheers,
> Adam
> [1]: https://github.com/lazaa32/pywps/commit/5cccc38c997965d4566b21df0badf3244021bdeb
> st 12. 12. 2018 v 2:32 odesílatel David Huard <huard.david at ouranos.ca> napsal:
> Hi Adam,
> I think we have the same issue : https://github.com/geopython/pywps/issues/412
> My guess is that it's either due to my refactoring or to the new templates or a combination of both.
> I noticed that if you do
> ComplexOutput.data = <file content>
> ... then it works
> but if you do
> ComplexOutput.file = <file path>
> it doesn't. Hopefully this is a hint as to what is going wrong.
> I think the offending bit is is inout.outputs.ComplexOutput. If the ComplexOutput is a file and as_reference is False, _json_data is called which I think might fail to fill the json data field. It's not obvious why though. Do you have a test case you could add to the test suite ?
> HTH,
> David
> On Tue, Dec 11, 2018 at 4:06 AM Adam Laža <ad.laza32 at gmail.com> wrote:
> Hi Carsten,
> thanks for reply. Good to know. However since I switched for master branch I can get output in ExecuteResponse only as reference. Even if I force attribute asReference=false I still get only reference to output, not the output directly.
> I use pywps-flask demo server and Buffer process for testing. Any idea what could be wrong?
> Cheers,
> Adam
> út 11. 12. 2018 v 0:16 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de> napsal:
> Hi Adam,
> yes, please use master branch to rebase. We switched awhile ago (Code sprint Bonn in March?).
> Cheers,
> Carsten
> > On 8 Dec 2018, at 04:16, Adam Laža <ad.laza32 at gmail.com> wrote:
> > Hi devs,
> > I'd like to make a new PR for my Docker extension in few days. Now I'm just bit confused because I wanted to rebase my branch onto develop branch to avoid conflicts but it seems to me that develop branch is no more used and that you use master instead (develop has last commit July 16, master 26 days ago).
> > Could anyone confirm that right approach is to rebase onto master and make a PR against master?
> > Thanks,
> > Adam
> > pywps-dev mailing list
> > pywps-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev
