[PyWPS-dev] master or develop
Adam Laža
ad.laza32 at gmail.com
Fri Dec 14 01:01:20 PST 2018
Done. [1]
A.
[1]: https://github.com/geopython/pywps/pull/432
pá 14. 12. 2018 v 21:29 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
napsal:
> Hi Adam,
> If you have an improved version of the bugfix could please open a PR?
> Here is the one from David:
> https://github.com/geopython/pywps/pull/431
> Cheers,
> Carsten
> > On 14 Dec 2018, at 09:10, Adam Laža <ad.laza32 at gmail.com> wrote:
> > Hi David,
> > Just cosmetics, I slightly edited the template. CDATA tag is not present
> if we know that mimeType is XML-based. Response XML looks better then.
> > A.
> > [1]:
> https://github.com/lazaa32/pywps/commit/f8b66e3f43f027ec3f20eacf9a82f9ac9c0e8499
> > čt 13. 12. 2018 v 8:00 odesílatel David Huard <huard.david at ouranos.ca>
> napsal:
> > Hi Adam, I've created a PR for your bug fix. Does it work for you ? It
> seems to work on my use cases.
> > On Wed, Dec 12, 2018 at 9:31 AM David Huard <huard.david at ouranos.ca>
> wrote:
> > Looks good, trying to write a few tests to exercise it.
> > Good catch !
> > On Wed, Dec 12, 2018 at 1:02 AM Adam Laža <ad.laza32 at gmail.com> wrote:
> > Hi David,
> > check my bug fix [1]. It works for me but I would like to know if it is
> right approach.
> > Cheers,
> > Adam
> > [1]:
> https://github.com/lazaa32/pywps/commit/5cccc38c997965d4566b21df0badf3244021bdeb
> > st 12. 12. 2018 v 2:32 odesílatel David Huard <huard.david at ouranos.ca>
> napsal:
> > Hi Adam,
> > I think we have the same issue :
> https://github.com/geopython/pywps/issues/412
> > My guess is that it's either due to my refactoring or to the new
> templates or a combination of both.
> > I noticed that if you do
> > ComplexOutput.data = <file content>
> > ... then it works
> > but if you do
> > ComplexOutput.file = <file path>
> > it doesn't. Hopefully this is a hint as to what is going wrong.
> > I think the offending bit is is inout.outputs.ComplexOutput. If the
> ComplexOutput is a file and as_reference is False, _json_data is called
> which I think might fail to fill the json data field. It's not obvious why
> though. Do you have a test case you could add to the test suite ?
> > HTH,
> > David
> > On Tue, Dec 11, 2018 at 4:06 AM Adam Laža <ad.laza32 at gmail.com> wrote:
> > Hi Carsten,
> > thanks for reply. Good to know. However since I switched for master
> branch I can get output in ExecuteResponse only as reference. Even if I
> force attribute asReference=false I still get only reference to output, not
> the output directly.
> > I use pywps-flask demo server and Buffer process for testing. Any idea
> what could be wrong?
> > Cheers,
> > Adam
> > út 11. 12. 2018 v 0:16 odesílatel Carsten Ehbrecht <ehbrecht at dkrz.de>
> napsal:
> > Hi Adam,
> > yes, please use master branch to rebase. We switched awhile ago (Code
> sprint Bonn in March?).
> > Cheers,
> > Carsten
> > > On 8 Dec 2018, at 04:16, Adam Laža <ad.laza32 at gmail.com> wrote:
> > > Hi devs,
> > > I'd like to make a new PR for my Docker extension in few days. Now I'm
> just bit confused because I wanted to rebase my branch onto develop branch
> to avoid conflicts but it seems to me that develop branch is no more used
> and that you use master instead (develop has last commit July 16, master 26
> days ago).
> > > Could anyone confirm that right approach is to rebase onto master and
> make a PR against master?
> > > Thanks,
> > > Adam
> > > _______________________________________________
> > > pywps-dev mailing list
> > > pywps-dev at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20181214/44d6ef00/attachment-0001.html>
More information about the pywps-dev
